Spark plugs
Old Aug 8, 2009 | 06:10 AM
05 Roadking Custom's Avatar
05 Roadking Custom
5th Gear
Cool Spark plugs
Can anybody recommend a good high performance spark plug? I recently rebuilt my motor (95 in kit, .590 lift cams).
Old Aug 8, 2009 | 07:58 AM
1flhtk4me's Avatar
1flhtk4me
Some run the NGK Iridium IX DCPR7EIX 6046.
Old Aug 8, 2009 | 10:59 AM
mp's Avatar
mp
I question how good the iridium plugs really are. I changed from regular NGK plugs to one range colder iridium after reading the article in Thunder Press about doing so with virtually any engine modification (I have an EV13 cam and free-flowing intake and exhaust). I experienced about a ten percent loss in fuel mileage on a 2000 mile trip. After going back to the standard NGK's for a 1400 mile trip, my fuel mileage returned to normal, which is an average of 49-51mpg on the highway. Nothing else was changed, other than the oil.
I like the NGK's because they seem more resistant to fouling when riding in changing elevations out west.
Old Aug 9, 2009 | 08:42 AM
XTrooper3936's Avatar
XTrooper3936
Unless you're spraying nitrous or running a boosted engine, there's no reason to go one range colder on your plugs. Try the NGK iridium plugs in the normal range, and I think you'll be pleasantly surprised.
Old Aug 9, 2009 | 09:07 AM
WildBill2566's Avatar
WildBill2566
Thats what I have run for the past 5 years on HD's and for a while before that on other makes of mc.
run as good as any other plug out there.
Old Aug 9, 2009 | 09:21 AM
ryanl's Avatar
ryanl
+1 on NGK
Old Aug 9, 2009 | 08:08 PM
Old Gunny's Avatar
Old Gunny
In the old days spark plugs were a big deal cause they fouled so bad. Was sulphur and lead in the gas. Had to change regullary.
Today a good name brand plug, maybe platium if you want to, will do the job.
I have run Iridum and they seemed just like the others. A spark is a spark.
Old Aug 9, 2009 | 08:15 PM
Dalton's Avatar
Dalton
You hit it right on the head, for a street engine and the compression ratios tht are run on the street, you don't need to go to platinum, iridium or a heat range colder.
I do run Autolite, direct replacement for the stock plugs that came in the bike, even though it is 120" and 10.5:1 compression. Runs just fine. The high end (and high $) plugs are a scam for street use.
Old Aug 10, 2009 | 06:35 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
NGK's here as well, and on builds at/near 10:1 or more, we set the gap @ .035".
Scott
Old Aug 10, 2009 | 10:11 PM
maineultraclassic's Avatar
maineultraclassic
Regular HD plugs will work just fine in a street motor. Or you can use the Autolite or Champion equal............they all work the same.
Steve
