Static Compression
Old Aug 12, 2009 | 10:28 AM
Tsarscott's Avatar
Tsarscott
Default Static Compression
I know it's been a while since I've done any posting, I'm back.
Can I have too much starting compression. Had some bad noises from my gear case or front cyl on a ride. Took it apart and rechecked everything all is good. Did a compression test today and came up with 170 psi front and 170 rear.
Over winter I put in new rings and honed cylinders.
1992 flstc,S&S "E",Hypercharger,V&H Big Shots Staggered,Crane Adj Pushrods,Crane 310-2 cam
Thanks
Old Aug 12, 2009 | 12:02 PM
paul s's Avatar
paul s
My 08 FXDF was 190/190 stock and went to 180/180 after cams. I don't think 170 would be too much.
Old Aug 12, 2009 | 05:30 PM
Kingofcubes's Avatar
Kingofcubes
Default ?'s
Did you inspect the lifters? How many miles on them? Do you have an oil pressure guage or just the light?
Old Aug 12, 2009 | 05:55 PM
Tsarscott's Avatar
Tsarscott
Lifters have about 70k on them. Just the light. It seemed as though the case was over pressurizing also, lost alot of oil thru the breather, I thought.
After I put it back together, I went and rode 70+ miles hard. Once parked I think I lost about a tablespoon of oil after parked. I don't think it's coming out of the breather, a little leak from the pushrod seals and maybe the lifter block gaskets.
Other than that runs freekin' great.
Old Aug 12, 2009 | 09:59 PM
02flh's Avatar
02flh
These stock PSI's are high or at least I think so. I thought stock was 120 or 140 something like that. Not stock can be all over the place but the same front and rear is Priceless. Tsarscott you heard the noise after you were cruising, right. now you mention the blow by, I would spend some thought on your oil pump and system, make sure it isn't pumping all the oil into the engine than loseing pressure (noise) and starting over again. Ya Know? welcome home. don over and out>>>
Old Aug 13, 2009 | 12:32 AM
paul s's Avatar
paul s
I took a Cold Cranking Compression reading before and after my cam swap to see what was going on and to put it in my logbook. I was happy that they were even, I didn't expect that.
Old Aug 13, 2009 | 08:37 AM
Kingofcubes
So the noise went away?
Old Aug 13, 2009 | 08:52 AM
Tsarscott's Avatar
Tsarscott
Yep the noise went away. Everything seems to be okay, still paranoid. This is my second Evo build/owned didn't have this problem b4.
Thanks for all help/advice.
Old Nov 7, 2010 | 08:17 PM
Mary Zorn's Avatar
Mary Zorn
Stage II
Default New Rings, honed cylinders, 1992 flstc, S&S "E", Hypercharger, V&H Big Shot...
Guess who helped Scott afford those things for his bike? Me. I didn't realize just how many things he changed. OUCH $$!! Thank you Scott.
Old Nov 7, 2010 | 09:05 PM
SURFOR Chop's Avatar
SURFOR Chop
Belay my last (didn't see Mary's other post)
Scott - glad the noise went away ....
