do you think I'm running lean?
Old Jun 1, 2006 | 10:43 PM
Sheldon's Avatar
Sheldon
Default do you think I'm running lean?
Picked up my new Heritage Classic a few weeks ago had the dealer put on the SE Air cleaner and Vance & Hines Pro pipe and to re-jet the carburator I thought they would do the air adjustment screw and both a low speed jet and main jet but all they did was put in a 46 low speed jet. But the bike runs Great Crack the throttle and no hesitation what so ever does not pop cough or nothing I have about 700 miles on it I havent tried to see what the top end speed was but I have had it wound up to 105 then backed off the throttle about an 1/8 turn no surging or belching or nothing Its hard to tell what my fuel milage is I've not been really running anything near steady been kind of up and down in all speeds The last tank was a pretty normal run fairly even at 60 to 70 miles an hour and i got like 42 mpg Do you guys think I'm running ok?
Thanks
Sheldon
Old Jun 2, 2006 | 09:47 AM
lonerider560's Avatar
lonerider560
Default RE: do you think I'm running lean?
Best to have it dyno'd by someone that knows what they are doing. Take it from experience if that bike is not tuned properly those propipes will blue and yellow very quickly.
Old Jun 2, 2006 | 10:50 AM
soz's Avatar
soz
You said the bikes runs great, no hesitation, no pop, no carb farts, no surging, no belching ETC.
I think you have answered your own question !
Old Jun 2, 2006 | 11:55 AM
Jip's Avatar
Jip
they didn't drill and adjust the idle mixture?
Old Jun 2, 2006 | 09:18 PM
Sheldon's Avatar
Sheldon
no they did'nt drill and adjust the idle mixture at some point I'm going to take it and put it on a dyno just have to find a place that actully know what they're doing
Thanks for the replys
Sheldon
Old Jun 3, 2006 | 01:36 AM
mp's Avatar
mp
There's no need to change the main jet. The stock bike only runs lean at part throttle, so the idle jet is all that needs to be modified on a basically stock bike. A lot of shops would rejet too big and kill your fuel mileage. As far as the idle, if it idles well, I guess it didn't need to be adjusted. I'd hesitate before I screwed up a great running bike by making it a dyno queen.
s.ga.rider
Sep 19, 2011 01:00 PM
GB_FXST
Sep 12, 2010 09:32 AM
all-one
Shovelhead
24
May 4, 2010 10:05 PM
SLC Rider
EVO
24
Oct 9, 2007 11:43 AM
Tompop
Jan 30, 2007 12:41 PM
