Engine problem
Old Jun 9, 2006 | 07:53 PM
boston_jake01's Avatar
boston_jake01
4th Gear
Default Engine problem
I just bought a 95 flhtc, I start it with the choke out and it will run fine but when i put the choke in it want to stall I increased the throttle adjustment just to keep it runnig but it's out quit a bit.
the rpm are about 1,000 which is too high. any ideas
Old Jun 9, 2006 | 11:17 PM
soz's Avatar
soz
Default RE: Engine problem
Are you sure 1000 is too high ?
The Harley-Davidson engine oiling systems needs 700 RPMs or greater to deliver proper lubrication
Probably between 900 and 1000 would be ideal for your carbed motor.
1000 to 1050 on a warm EFI motor. (1500-1600 cold)
Old Jun 10, 2006 | 01:01 AM
boston_jake01
4th Gear
no I'm not really sure I haven't recieved my service manual, so I'm not sure but it does sound high compared to my sportster. and the throttle adjustment seems out far.
Old Jun 10, 2006 | 01:08 AM
tripl8's Avatar
tripl8
1k rpm is just right for an EVO oil pump.Take that carb apart and soak it/clean it.
Robtarra39
Aug 13, 2013 08:42 AM
Antmf
Jun 6, 2013 04:56 PM
wildroot
Jul 26, 2011 09:45 PM
mchaous
Oct 31, 2005 06:16 PM
