loss of idle quality after burnout
Old Aug 30, 2009 | 08:38 PM
02WideG3's Avatar
02WideG3
6th Gear
Default loss of idle quality after burnout
I am not sure how to ask this question but after doing a burnout with bike which is a 2002 dyna wideglide carb mikuni hsr42 v&h straight shots and air cleaner k&n .idle sounds like i have no base timing i am currently using the se mapable ignition module .i am on curve 1 for stock bikes i used to ping at about 5 degrees advance and ran it at 3 degrees for 4 years now i dont even ping when i put it up to its max a 6 degrees idle quality got better doesnt sound flat but it doesnt sound right i would of figured i flattened the valve springs being up on the rpm .could i have did something to the crankshaft to throw off timing or am i barking up the wrong tree and should look elsewhere thanks if someone could shed some light here
Old Sep 2, 2009 | 11:13 PM
genedjr's Avatar
genedjr
Sounds like goo got into your carb.
A good gas cleaner may help.
If you bent something it would be bad everywhere.
...gene
Old Sep 10, 2009 | 05:14 PM
02WideG3's Avatar
02WideG3
6th Gear
Gene,thanks for the reply i tried to clean out carb also used a good carb to test same thing .i figured the same if i bent something it would be bad everywhere .i was thinking maybe carbon buildup and just coincidence for the idle after burnout or the venting of the gas tank too .would a weak valve spring be a possibility?thanks Kenny
Old Sep 10, 2009 | 07:27 PM
SportsterBob's Avatar
SportsterBob
Does any of the smoke from "lighting up" the tire get sucked into the intake?
lmz5150
EVO
29
May 12, 2017 02:41 PM
BigMESA
Carburetor Related
13
Jan 3, 2017 05:10 PM
daveMD2011
Jun 11, 2012 06:23 AM
02WideG3
Aug 31, 2009 09:37 PM
brooksweith
Jun 3, 2007 10:55 PM
