trouble
Old Jun 13, 2006 | 01:32 PM
trouble's Avatar
trouble
Stage II
Default trouble
I have a 1989 fxrs sp with no modes. Lately the bike will not take fuel under no load . Have no problem with idle or under power .Any sugestions
Old Jun 15, 2006 | 01:14 PM
Spectrexx's Avatar
Spectrexx
Default RE: trouble
What do you mean by "under no load"? The engine is either idling or under power.... one of the other. Can you be more specific? The more information we have, the better we can help you.
Has anything on the engine changed before the problem started? It could be bad gas, a clogged fuel filter, or the carb might need a rebuild and/or adjustment. It might also be spark plugs or wires. What does your factory service manual say in the troubleshooting section? If you don't have the book, I'd get one ASAP before you start messing with anything.
Old Jun 15, 2006 | 07:01 PM
trouble's Avatar
trouble
Stage II
Default RE: trouble
thanks for the reply I meant that the bike does not rev easily or without backfiring when idling or downshifting.When riding it is fine and takes gas and responds well.
Old Jun 15, 2006 | 10:57 PM
tripl8's Avatar
tripl8
Default RE: trouble
Intake and exhaust leaks.
Old Jun 19, 2006 | 12:28 PM
Spectrexx's Avatar
Spectrexx
Default RE: trouble
ORIGINAL: tripl8
Yup... sounds about right. I'd rebuild the carb while it's off and then dyno-tune it. It should run fine after that.
LOVECHUNK
Feb 28, 2018 12:34 PM
thunder7
Sep 26, 2012 10:59 AM
bmassarani
Ironhead
23
Dec 12, 2011 08:01 PM
Dave1977
Aug 15, 2007 01:22 PM
shagga
Mar 27, 2007 08:03 PM
