No power/Bike stalls while giving throttle.
Old Feb 28, 2018 | 10:35 AM
LOVECHUNK's Avatar
LOVECHUNK
Stage III
Default No power/Bike stalls while giving throttle.
So just like the title says, when I ride my 01 Fatboy, I can get about 5 minutes down the road, engine pops on turns off then when throttling the bike seems as if it is not getting any fuel and will stall out or just have 0 power.
I just had the intake seals replaced, complete fluid change, and reset the bikes brain by taking it off the battery for about 30 minutes, reconnecting it and letting idle for about 10 minutes. Issue is still present.
Now for the strangest part of it all, if i'm driving and do not have to stop the engine will come on turn off, bike will not get power/stall out if i try to go faster, but if i cruise the engine light will come back on turn off and the issue is gone for the rest of the ride. Once I restart the bike from sitting for a while the issue starts all over.
Please help!
Old Feb 28, 2018 | 10:41 AM
J_MOSH's Avatar
J_MOSH
Junk spark plugs? Any time I have these symptoms on anything ive owned ill clean my carb and do new plugs and it Usualy works. But I suspect your injected so carb clean won't work. Perhaps do a fuel system cleaner and dry gas. May have picked up some moisture over the winter.
Old Feb 28, 2018 | 10:56 AM
LOVECHUNK's Avatar
LOVECHUNK
Stage III
Forgive my ignorance, what is dry gas?
What fuel cleaner do you suggest?
Yes it is injected.
Old Feb 28, 2018 | 11:01 AM
J_MOSH's Avatar
J_MOSH
Dry gas is this stuff that eats up water that gets into fuel systems. If the bike has sat for more than a year the fuel itself may be garbage. The new gas doesn't age well and will leave a nasty green film in everything and make it run like crap.
Old Feb 28, 2018 | 11:10 AM
Clammy's Avatar
Clammy
Reaper's carbed, but I've read plenty of threads relating to FI, and a very common problem is the fuel line inside the tank developing a pinhole leak, thus starving the bike for fuel while riding. You might want to take a peak at that.
Cheers!
Old Feb 28, 2018 | 12:34 PM
LOVECHUNK's Avatar
LOVECHUNK
Stage III
Thanks yall, I will try and take a look this weekend. If it indeed is a pinhole leak in the fuel line, why would it resolve itself after a little bit of riding.
adamk
Jul 12, 2017 06:47 PM
seniorsuperglideE8
Feb 25, 2017 01:54 PM
iplaye9
Aug 20, 2011 06:28 PM
wodom1
Jun 12, 2010 10:57 AM
GypsyRoseTattoo
Exhaust System Topics
Jun 26, 2009 09:36 AM
