2014 Breakout
Old Feb 26, 2018 | 06:24 PM
vivid black's Avatar
vivid black
Default 2014 Breakout
Is anyone else have problem with oil seeping back to crankcase from tank on Breakout after setting for two or three months? Will this cause problems with engine? Thanks
Old Feb 26, 2018 | 09:43 PM
02603SEC's Avatar
02603SEC
Not sure if it's a common problem, but I have seen it happen once on a friends bike. He just purchased a used 2003 Fatboy that sat at the dealer for a while, it ended up puking out of the intake, down the side of his bike and all over his right pant leg. He was told to put some miles on the bike, then check the oil hot and top off as needed. It did not do any damage to the bike.
Old Feb 26, 2018 | 10:44 PM
cdonis's Avatar
cdonis
My bike never sits that long ,but does have some oil drain down after being parked. After starting it and warming up all is normal. I'm talking cold checking at the bottom line on the dipstick, and rechecking about half up after warm-up where I run it.
Old Feb 27, 2018 | 05:28 AM
vivid black
On this bike it was all the way off dip stick had oil changed at dealer rode several times after change put up at start of winter (Indiana) check tank the other day before and nothing on stick. There must be a valve or something seeping or something it was at right level after change(synthetic)? Had bike since new and low miles on bike.
Old Feb 27, 2018 | 08:45 AM
cdonis's Avatar
cdonis
Virtually all softail do it. Some more than others.
Old Feb 27, 2018 | 09:46 PM
press, lean, and roll's Avatar
Right. I thought it was normal.
Old Feb 28, 2018 | 01:02 PM
vivid black
Thanks for replys !!
matt_m_72
Apr 21, 2019 07:17 AM
boom215
EVO
Nov 13, 2013 10:28 PM
harleyfiremedic
Jul 20, 2011 03:41 PM
Vinny133
Oil Archive (no new posts)
Mar 12, 2011 05:16 PM
WARG
Jun 20, 2007 03:54 PM
