i have a 67 sportster shovel head and the front cylinder is not working it is a fresh rebuild and was working up until 50 miles now i can put my hand rite on the jug and it is just warm.
Not to be too picky, but being an old fart I'm allowed to be - - A Sportster isn't a Shovelhead, but known as an Ironhead. Shovlehead is a Big Twin engine. Unless you have a Shovester, which is a Sporty bottom with a Shovel grafted on top.
Have you checked to see if you have spark? Something easy to try is to swap the plug wires at the coil end only. If the rear cylinder quits firing, then you've got either a bad coil, or a bad plug wire. Coil, plug wires, plugs. It's just about gotta be one of those three.
Good advice from above, if you are getting spark or it's not the plug, or coil you might want to do a compression check, just in case something happened to the fresh rebuild, ie broke valve spring etc. Keep us informed to what you find.
ok the engine has 150lbs of compresion new plugs 018 gap new points 015 gap good spark both plugs. i have double checked timming and valve lash, double checked valve seats. i will say i am confussed about the skinny lobe and fat lobe on the mag. it runs when timed on the skinny lobe, but not at all when timed on the fat lobe
allright i think the proplem is my mag does anyone know how to test it, i am getting 15000 ohms between the two spark plug out puts, and i am getting zero ohms from the red wire lead to ground. any help on this topic did i test it right?
I don't have anything handy to tell you how to check your mag. Drop by this site and e-mail, whatever, this guy. Buck's a magneto guru. http://www.goblinmillworx.com/
