Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Just became a first time owner of a Harley, and it happens to be a 77 Sx250 (250cc AMF 2stroke).
It is a basket case project bike, however around 90% complete between a rolling chassis and the Basket of parts.
The one thing I cannot wrap my head around tight enough to figure out is the fact it runs 2 spark plugs in a single cylinder from a single ignition coil.
I though I might have been crazy and it was missing a coil,but according to the wires in the loom (still factory taped and wrapped) this is not the case.
FOR SANITY'S SAKE CAN SOMEONE BREAK IT DOWN FOR ME??
Do I need some special park plug wire? Maybe I am missing some kind of coil to coil jump lines AND the other coil?
Nope if I am right all Harley's fire on both intake and exhaust stroke so the coil is always firing no matter what. The rest I cant explaine how it works
It` a two stroke engine...it completes an intake, compression, combustion and exhaust cycle on every revolution.
One of the holes may have been for a compression release, I remember when they would fail we would yank them out and just put a spark plug in the hole just to plug the opening......
