Question ??
Old Oct 28, 2009 | 07:39 AM
jhnmflr's Avatar
jhnmflr
Default Question ??
Was getting ready to install top end and cam upgrade . Ev3 cam , JIms lifters , + 0.010 wiseco 10:1 pistons . New valves , springs and headwork . When checking ring gap I have .024 / .023 on both jugs on top and bottom . Pistons are 3.508 and noticed machine shop invoice states jugs are 3.510 . Seems correct to me , possibly wrong rings in piston kit ? What's the next step ?
Old Oct 28, 2009 | 10:59 AM
djl's Avatar
djl
End gap varies from one manufacturer to another but a general rule of thumb for a modified four stroke engine is:
top ring = bore x .005
second ring = bore x.006
Looks like you may have all second rings? Call Wiseco and check with them.
Old Nov 8, 2009 | 11:15 AM
jhnmflr's Avatar
jhnmflr
Well my numbers were wrong . wiseco says the pistons are 3.506with skirt coating .
Machinist bored to 3.509 cause he measured pistons at 3.507 . I measured bore at top and botom and got 3.509but I measured piston at 3.506 . So .003 piston clearance . I ordered a 10 and 20 over se of rings thinking maybe the first set was packaged wrong , stll had .024 ring gap . So i used the 20 over rings and filed them . Put it all togethe this weekend and went through a couple of heat cycles yesterday and took it for a little jaunt today ( 3 mile sor so ) . So far so good .
Just wanted to update the post
Old Nov 8, 2009 | 03:15 PM
1flhtk4me's Avatar
1flhtk4me
Someone's mic must be off!
Rad10
Apr 27, 2017 02:58 PM
Meatpants
Shovelhead
Mar 27, 2017 07:28 PM
cthowards
Mar 5, 2016 11:54 AM
harley_jeff
Apr 9, 2012 07:52 PM
Americanbear
Oct 22, 2007 08:49 PM
