1200 conversion question???
Old Jul 6, 2006 | 11:09 PM
tim@tmgdesigns's Avatar
tim@tmgdesigns
Default 1200 conversion question???
I am looking to convert my 883 to a 1200. In-order to figure the compression ratio, I need to find the volume of the head. Does anyone know what it is for an 02 XL? I know that the higher the compression the more power but at what point is this counter productive for a daily driver and going from 9:1 883 to 9:1 1200 or should I look at getting the 10.5:1. My other question is about KB pistons. Are they any good? They seem much cheaper than Wiseco.
Old Jul 7, 2006 | 02:45 PM
bobcowan's Avatar
bobcowan
Default RE: 1200 conversion question???
Static compression isn't as important as dynamic compression (cylinder pressure). You can run a high compression motor if the cam and altitude are right. I run 10.25:1 with a 204 cam on cheap pump gas. But I live at 6,400' ASL. Cylinder pressure is only about 180. Anything over 195'ish is going to be a problem.
Go to RBR Racing's web site. They have some calculaters there that will help you out.
Unfortunatly, I can't help you with the head question.
KB Hypereutectic piston are excellent for a moderate compression motor without any power adders. I wouldn't hesitate to use them again.
ib5150
May 14, 2015 06:13 PM
SMorty00
Sep 18, 2013 12:34 PM
883Frankenbike
Nov 26, 2012 06:45 PM
Will-N-Missouri
Jan 24, 2011 05:24 AM
tim@tmgdesigns
Jul 6, 2006 06:11 PM
