09 FLTR engine issue
Old Nov 9, 2009 | 09:00 AM
fripple's Avatar
fripple
Default 09 FLTR engine issue
I've been having this weird issue in only 5th and 6th gear.
I'll be going down the highway 70mph 6th gear. I'll open the throttle wide open and I get a hesitation and then the rpm's jump way up and the 6th gear light will go off.
It does the same thing in 5th gear when I open the throttle wide also. All other gears, it just seems to pull instead of hesitating.
Back in July I had SE-204 cams along with a race tuner installed. It started having this problem about a month ago. Any ideas? I'm stumped.
Old Nov 9, 2009 | 05:22 PM
KaponeWKYA's Avatar
KaponeWKYA
This could be caused by the new (in 08) Throttle By Wire the MOCO switched to. My 08 pretty much does the same thing. I'm not a wrench, so take this with a grain of salt...
Old Nov 9, 2009 | 05:30 PM
splitting_lanes's Avatar
splitting_lanes
sounds like your clutch may be slipping. the added torque can cause that.
Mine did the same thing, so I switched my clutch spring to the SE heavy-duty version and haven't had any slippage problems since. the down-side is you lose that easy clutch pull...
Old Nov 9, 2009 | 05:40 PM
KaponeWKYA's Avatar
KaponeWKYA
This could be the culprit and I also changed to the Screamin' Eagle clutch and no longer have the issue...
Old Nov 9, 2009 | 08:10 PM
07RoadHawg's Avatar
07RoadHawg
Bingo.
Old Nov 9, 2009 | 08:39 PM
rbabos's Avatar
rbabos
Yup, sounds like clutch slip. Whenever the rpms are wrong for what the speed sensor is showing in 6th, the light will go out. Problem many have with sprocket changes. 5th and 6th will placed the most load on the clutch and problems usually show up there first.
Ron
Old Nov 9, 2009 | 10:17 PM
fripple's Avatar
fripple
maybe i'll try out the SE spring first. Thanks guys!
aaronmcb80
Dec 29, 2016 03:36 PM
mwmpatterson
Sep 17, 2015 11:05 AM
Moondogger
Oct 10, 2012 09:38 AM
luke2692
Jun 19, 2011 05:42 PM
dgretz
Aug 24, 2010 09:55 AM
