Priming engine before start up
Old Nov 11, 2009 | 05:23 PM
Puttnutt24's Avatar
Puttnutt24
Default Priming engine before start up
Hello,
I just finished installing new cams and lifter's in my 2010 Twin Cam. Is there a way to prime the oil system prior to the first start up?
Old Nov 11, 2009 | 06:33 PM
Kingofcubes's Avatar
Kingofcubes
I use lots of oil on the gyrotors on install and call that good. Let it sit overnight with the feed line hooked up or pressurize the oil tank slightly and turn the engine over untill you have pressure.
Old Nov 11, 2009 | 08:05 PM
KumaRide's Avatar
KumaRide
If you lubed the crap out of the oil pump, you can turn the rear wheel in 5th/6th with plugs removed. I did that to verify pump was working after installing cams and prior to putting push rods back in, then rocker covers back on. Anyway, could see oil going where it should
Another thing - you probably changed oil and filter, it helps to poor oil directly into the oil filter saturating the filter pleats prior to installing it. Oil pressure will build up quicker this way...
Old Nov 11, 2009 | 09:00 PM
prodrag1320's Avatar
prodrag1320
also,make sure you put about 1/4 quart of oil down one lifter block hole after youve got the cam cover back on
kirby
happychappy
11
Feb 21, 2013 06:12 PM
stang32903
Oil Archive (no new posts)
Feb 17, 2009 09:15 AM
evil joker
Jan 15, 2009 12:34 PM
Lemmy
Jun 3, 2008 04:00 AM
Scout
Jun 2, 2006 12:54 AM
