Need more Grunt
Old Dec 14, 2009 | 12:32 PM
07RoadHawg's Avatar
07RoadHawg
Originally Posted by grbrown
Good suggestion. All Harleys are way over geared. I changed the crank sprocket on my Dyna from 25T to 21T to wake it up. That gives a 19% increase in torque at the rear wheel for just a few bucks. Unfortunately latest Harleys use a different design of crank sprocket and I don't know of any replacements being available yet. That is the best place to make gearing changes.
FWIW, Evolution Industries makes a 30 tooth crank sprocket (no compensator) and a 49 tooth clutch basket sproket. On the TC96 (at least for 07 & 08), the engine sprocket is a 34 tooth and the clutch basket is a 46. I went with the 49 tooth over the 30 tooth just to keep the compensator sprocket in place. Happy with the results so far. IIRC, it gave me about 300 more RPM in 6th on the highway, and starting on an incline is much easier especially when 2-up.
Old Dec 14, 2009 | 12:36 PM
HDWRENCH's Avatar
HDWRENCH
any dyno sheets on the cam yet?? specs on cam ?? be nice to see how it works.
Old Dec 14, 2009 | 02:07 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Default Cam specs
This is the tale of the tape:
intake----- 20/45, 245 dur., .570 lift, 102.5 center
exhaust----47/18, 245 dur., .570 lift, 104.5 center
From 98" to 124". This took some time to design, in-house, and had another in the works, a couple years ago, but the bottom fell out of that. Different story, and in hind sight, glad it did.
Mike Pederson, GM of Andrews, said it looks VERY good.
Scott
Old Dec 14, 2009 | 06:51 PM
Dalton's Avatar
Dalton
Scott
Free Samples ??? I know -->
I'll go back and sit in my corner now.
Old Dec 14, 2009 | 08:59 PM
Keithhu's Avatar
Keithhu
Question about the re-gear - doesn't that mean higher RPM's at cruising speed (say 75 MPH in 6th?)
Old Dec 15, 2009 | 08:37 AM
07RoadHawg's Avatar
07RoadHawg
Yes. That was done by the factory on the '10 models. The '07 & '08 really benefit from some extra rpm in 6th.
Old Dec 15, 2009 | 09:40 AM
Mr Cujo's Avatar
Mr Cujo
Matrix,
What fuel economy changes did you see with the gear change?
Old Dec 15, 2009 | 11:01 PM
producer's Avatar
producer
Question; Please correct me if I'm wrong, but why would you want to change the pulley ratio and sacrifice nice easy cruising and gas mileage on the highway in 6th gear? I admit, I don't know much about this pulley stuff.
The right cam and the right tune seems like a solid direction to go.
Old Dec 16, 2009 | 06:34 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
I'm sorry for the lag in response time to the replys to the question(s) that I posted but when you have a J O B to deal with, sometimes we all get a little too busy. I thank you all for your input and you have given me a defininte place to start with with my need for more low and midrange end GIDDYUP. Seems like I need to do a little more reading and investigation on this forum regarding my topic as I know there are lots of Ya out there that have more mechanical knowledge on this than I do. Again thank you and it sounds like a 30t sprocket along with the proper camming will open her up.
Old Dec 16, 2009 | 09:28 AM
07RoadHawg's Avatar
07RoadHawg
Originally Posted by Mr Cujo
Matrix,
Not really any change. I actually get about the same on the hwy as before and about 2 mpg better in 5th on the two lane roads. The engine is working easier and requires a little less throttle to keep the same speed.
