Torque Cones
Old Jan 4, 2010 | 07:08 PM
JesseMFE's Avatar
JesseMFE
Stage II
Default Torque Cones
Ive heard that straight pipes make the cylinders run to hot because there is not enough back pressure, so if you use torque cones will it eliminate this problem.
Old Jan 4, 2010 | 08:08 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
They would cause and engine to run hot if running too lean, as most any open pipe will want more fuel, but the torque cones are right in the path of the raw flame.
A better way to control the reversion, that an open pipe presents, is on the other end of it. Believe this or not, but a 1/4" bolt, 1 1/2" long, stacked with 3-4-5, 5/16" nuts, then nutted with the 1/4" nut, will allow the reversion to be almost totally controlled, without pinching off the horsepower.
Ancient Chinese Dyno Tuning trick.
Scott
Old Jan 4, 2010 | 08:43 PM
paul s's Avatar
paul s
This is what the back of a BCT QQ looks like, it's a washer.
Old Jan 4, 2010 | 08:58 PM
prodrag1320's Avatar
prodrag1320
torque cones work good for stock evo`s to get back alittle torque,but any kind of built motor,as scott said, the bolt thing works pretty good,old school dyno trick
kirby
facebook:kirby apathy
Old Jan 5, 2010 | 10:55 AM
98 FLHX's Avatar
98 FLHX
Scott
...and I thought it was a Midwestern thing......
Old Jan 6, 2010 | 07:44 AM
hawkdsl's Avatar
hawkdsl
Saw this some time ago. May be of interest.
http://www.nrhsperformance.com/tech_arcones.shtml
Old Jan 6, 2010 | 11:19 AM
JesseMFE's Avatar
JesseMFE
Stage II
All great Info. Thanks.
Coastal CVO
Mar 19, 2018 08:08 AM
Derf_
Feb 10, 2018 07:25 PM
galaxyfe
Engine Mechanical Topics
Aug 22, 2015 07:33 PM
aggro_jo
Samson Exhaust
Sep 9, 2010 12:27 PM
jstartz
Feb 9, 2005 12:02 PM
