SE Rocker Arms 1.725:1
Old Feb 3, 2010 | 01:56 AM
Rebel78's Avatar
Rebel78
So is this upgrade recommended or not?
Old Feb 3, 2010 | 09:54 PM
Dalton's Avatar
Dalton
I have to agree with ProDrag here, if you want the lift, buy the cam for the application.
Old Feb 4, 2010 | 08:58 AM
rmc115's Avatar
rmc115
I am running that combo now and with the formula they include it worked out to .572 lift. stock springs have worked fine. Nice upgrade if you already have a cam you like. Mike
Old Feb 4, 2010 | 06:43 PM
Old Gunny's Avatar
Old Gunny
It will very slightly increase the duration also.
The valve will be at 0.053 lift sooner a little bit.
Old Feb 5, 2010 | 06:21 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Have seen others use that without issues.
Scott
Old Feb 5, 2010 | 01:49 PM
Old Gunny's Avatar
Old Gunny
If I had a cam I liked, just wanted to raise the lift a little and had a set of these rockers around I would do it.
Easier that a cam change.
It'll raise a .575 cam to about to 0.600. Not too bad.
But S&S rollers cost a lot. About what a cam costs.
Old Jun 12, 2010 | 06:14 PM
SC-Longhair's Avatar
SC-Longhair
I know this is an old thread but I'm wondering....
If you're trying to create a higher lift through rocker ratio change....why not just find a cam with the approximate lift you want to begin with? Wouldn't that make more sense?
In most cases, changing the rockers to a higher ratio version is just as costly if not more so than buying a new cam although less intrusive as the rocker box is relatively easy to gain access to.
I am a total newb to performance work on v-twins and just trying to understand.
Also, since we're discussing lift...I've looked high and low for it. Do you know the max lift on a set of stock 06+ heads? I haven't had my wood tw6 cams in for a month yet and already looking at either the tw5-6 or tw7 which are both hi lift cams but state on Wood site (use with stock heads) @ .575" lift.
I would figure Bob W. wouldn't steer anyone wrong, at least I hope not....
Old Jun 12, 2010 | 08:30 PM
paul s's Avatar
paul s
When I bought my cams I didn't know the springs could handle more lift, my heads were coming off anyway so doing the rockers for about 150 to my door was an easy fix. I do like the TW5-6 and if I knew what I know now they would be in my bike. I get tempted to do it still but I'm not sure if the .34 more lift and 1 less degree in intake valve closing would be worth the time and price.
Old Jun 13, 2010 | 01:16 PM
Old Gunny's Avatar
Old Gunny
I think the arm reaching to the valve stem is the same as stock, it is the arm the pushrod fits into that is a little shorter. To get the ratio.
As Hillside said would be OK for a cam going from, .555 to, .590. Any higher and a roller tip is needed.
Which brings that question up. I really like S&S roller tips. and the reason is the longer bushions inside. Labor is the same.
Old Oct 3, 2010 | 05:02 PM
Stoood's Avatar
Stoood
SHOULD inrease torque, and broaden duration slightly; that's what they were designed to do per the motor builders I know. Chevy's version sure Did It for my 350CI HO motor in my Firebird Trans-Am. CHEAP power if you pay attention to clearances (BUT, see my posting on the issues I am having with a TQ build 103 motor). It's looking more like an exhaust tuning issue now. Per one engine builder I know, you'll be fine w/ the cross-over pipes or 2 into 1's with a bit of back pressure and good scavanging. Use a set of SE Conical "Beehive" springs, good for 0.685 lift and no float, no bind. I'm using them and like 'em.
-Stoood
