Heritage won't start
Old Mar 2, 2010 | 06:36 PM
Mark Boshart's Avatar
Mark Boshart
Stage I
Default Heritage won't start
I was idleing my '03 Heritage twin cam EFI 88 in my garage to maintain battery charge, and it ran out of fuel. Put in new premium fuel, it cranks, but will not start. Normally starts in about 1 second.
All lights are normal, can hear normal sound when placed into run position with main switch on. Red engine light on on speedometer goes out as normal. Cranking sound is normal, just no fire up, not even a little. Red oil light goes out when cranking, normal oil level.
I Sequenced main switch and run switch numerous times to clear air out of line (about 20-30 times over a few days). Old plugs had spark and looked normal. Replaced plugs anyway, they have spark. Checked compression, 130 on both cylinders. Smelled plugs after cranking, they have gas on them. Replaced air filter. Cranks normal, good battery, no startup.
Any Ideas?
Old Mar 2, 2010 | 06:58 PM
SEDELUXE's Avatar
SEDELUXE
ok probley vapor lock take the fuel line off and put back on then try and start.
take gas cap off when trying also try and see if fuel pump fuse is blown
Old Mar 3, 2010 | 06:11 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
If it is a carbed bike, check the vacuum petcock for correct operation.
Scott
Old Mar 3, 2010 | 06:14 PM
riskyfool's Avatar
riskyfool
Some of those with more expertise may chime in on this, but on some bikes the stator doesn't kick in until higher rpms. Therefore when you start the bike and only let it idle, it is running entirely off of the battery. Maybe this is the case here too.
Old Mar 17, 2010 | 05:07 PM
rbmalone2000's Avatar
rbmalone2000
Stage III
I have the same exact problem. Except I have a fuel injected 2006 road king classic. Did you ever find a fix? I could use the help as well.
Thanks
Old Mar 17, 2010 | 08:17 PM
Old Gunny's Avatar
Old Gunny
It is something, probably a inter-lock in the ECM keeping the coil from firing.
right now I would look in the owners manual for something to reset.
Its FI, got gas to the cilenders, cranks. Won't fire. Ecm more that likely doing this on purpose. check that out.
Old Mar 17, 2010 | 09:33 PM
ajayrk's Avatar
ajayrk
Squirt some starting fluid into the intake to see if it will fire.
Pull the fuel line and depress the plunger in the quick coupling to check for pressure. Be sure it is pointing away from you.
No pressure may mean a fuel pump failure.
Sometimes a fuel pump that runs dry will seize.
ajayrk's Avatar
ajayrk
OK, how do I get rid of a double post?
Old Mar 18, 2010 | 05:34 AM
rbmalone2000
Stage III
I tried pouring a little gas in the intake no help. Tried a little starting fluid in the intake as well no help. I'm going to try and disconnect the battery to see if that resets anything. I'll post a fix when I get it under control. Thanks for the advice. Hopefully I'm on the road soon!!
Old Mar 18, 2010 | 04:35 PM
rbmalone2000
Stage III
Back on the road!! Pulled both plugs cleaned them up(have to get new plugs asap), Disconnected battery, and pulled ignition breaker it was good so I reinstalled it. Cranked it over and it was good 2 go. Most likely had to be the plugs they looked pretty bad. Anyway thanks to all who helped.
Later,,,,, and I wish all a good safe riding season!
