Fuel in Crankcase!!!!????
Old Mar 13, 2010 | 05:21 PM
rebharbin's Avatar
rebharbin
Stage II
Default Fuel in Crankcase!!!!????
Let me start by saying I forgot or neglected to turn off the fuel valve before storing my bike over the winter. Every 3 or 4 weeks I would go out and start it with no problems. It has been about 6 weeks since I last started the bike. I was preparing to change the oil so I start it up and let it run, after about 2 minutes it begins to run poorly. I shut off the choke and it continued until the bike shut off. Gas was pouring out of the air filter. I removed the carb and found a dry rotted vac cap. I replaced the cap, reinstall the carb. When I checked the oil it was full of fuel. I guessed that it had created a vaccum with the cap being rotten and filled the crankcase. So I change the oil fire it up it runs for a few minutes and shuts off. Check the fresh oil change and low and behold......gas again. What in the world could cause this? Thanks in advance for any guidance.
Old Mar 13, 2010 | 05:32 PM
PistonPuller's Avatar
PistonPuller
First thing that comes to my mind is a stuck float. If you are getting a lot of gas in the crankcase, I would not be running it too often or for to long.
Old Mar 13, 2010 | 06:07 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The fuel is going past the needle and seat in the carb, probably a bit of trash is lodged in there. Sometimes you can clear it by running the engine with the fuel shut off, until it runs dry, that may clear it up.
If not, you will need to remove the fuel bowl from the carb and give the needle and seat area a shot of carb cleaner.
Some unsolicited advice...
When you store the bike for extended periods, add fuel stabilizer and fill the tanks full.
Run the engine with the fuel valve in shutoff, until the engine quits.
Always turn the fuel valve off except when the engine is running. Make it a habit. Don`t trust vacuum valve shutoffs.
When the bike is stored for extended periods, don`t start the engine unless you plan to take it for a ride that is long enough to get the engine and oil hot. Short engine runs cause condensation to form inside the engine and oil tank, this is why many people find milky white stuff in the engine oil.
doakley2
EVO
18
Nov 28, 2019 07:47 AM
Floyd R Turbo
Oct 27, 2013 09:56 PM
wyazel1
Mar 26, 2012 01:59 PM
CS Mactavish
Feb 26, 2012 09:10 AM
rebharbin
Mar 13, 2010 06:38 PM
