S&S super E popping out carb 60-70 mph
Old May 5, 2010 | 04:14 AM
97CMC's Avatar
97CMC
Default S&S super E popping out carb 60-70 mph
At about 60-70 mph I get random here and there pop pop out carb. It’s like the engine hiccups. It's a 88” S&S with super e carb. I have baffles in the pipes. Sparkplugs look great. It has a forcewinder air cleaner. I removed the bowl vent plug like S&S recommends. Anywhere other than 60-70 mph is great including full throttle. I just got this bike. Any ideas?
Old May 5, 2010 | 05:47 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Pull the bowl off that and check to see what jetting you have on the pilot, and the main, in order to reccomend the suspected proper size.
Has the classic symtoms of a lean condition.
Scott
Old May 5, 2010 | 08:34 AM
shadylane's Avatar
shadylane
"HSC" Has some good advice. I run my mid-range mixture on the lean side. When its cold outside occasional carb farts are acceptable. Above 70 degrees, There should be none after the engine warms up. The other option is to change pilot jets with the seasons. The Idle mixture will have to be varied as necessary.
Old May 5, 2010 | 08:46 AM
lionsm13's Avatar
lionsm13
Here's one I suggest that you print out:
http://www.bikernet.com/SandS/PageVi...sp?PageID=1198
Old May 5, 2010 | 06:07 PM
97CMC's Avatar
97CMC
I rode this morning “40 degrees” and it was popping like insane. Ya my next step on the list is checking the jets. Would a intake leak cause this? I’ve checked and checked. How about if the previous owner added the high flow intake and didn't reject?
Old May 5, 2010 | 09:00 PM
97CMC's Avatar
97CMC
Does this sound like a intermediate or main jet problem?
Old May 6, 2010 | 06:11 AM
Hillsidecycle.com
Sponsor
Sounds like an intermediate jetting issue.
Scott
Sundog
Nov 5, 2016 10:31 PM
arrowslinger1980
Oct 14, 2011 11:18 PM
Sheets1958
Sep 18, 2011 06:41 PM
90ssharley
Carburetor Related
Mar 1, 2009 06:57 AM
Rolson1
Ironhead
11
Sep 21, 2007 12:58 AM
