screamin eagle heads
Old Jun 9, 2010 | 08:05 PM
waynemags's Avatar
waynemags
Default screamin eagle heads
ive got screamin eagle heads on my newly aquired 99 roadking. its got the 95" bigbore setup. not sure yet what cams. my question is about the heads. does anyone know what lift these can handle, what size valves are in them, and what they flow? anyone have info would be great. thanx
Old Jun 9, 2010 | 08:09 PM
prodrag1320's Avatar
prodrag1320
it depends on what SE heads they are,different heads vary quite a bit,any casting #`s on them?
Old Jun 9, 2010 | 08:31 PM
waynemags's Avatar
waynemags
all i can see is 16927-95 and undr that theres 8000 P. inside the round part on the P there is a plus sighn. thats the best i could finfd. these mean anything?
Old Jun 10, 2010 | 12:03 PM
Firetender's Avatar
Firetender
The SE heads of this era list .575 max lift. Definitely not for use out-of-the-box without work, IMHO. Here's some info:
http://www.baggersmag.com/tech/0205h...ead/index.html
PN 16952-99B: We’ve combined the proven Screamin’ EagleŽ valve train components and innovative port shapes from the EvolutionŽ 1340 cylinder heads with the Twin Cam 88Ž engine “bathtub” combustion chamber to create a cylinder head that really performs. These heads offer a bolt-on compression ratio of 9.5:1 for a Twin Cam 88Ž (1450) and 10.0:1 for a Big Bore Twin Cam (1550). Combined with forged high compression pistons, both 1450 and 1550 engine configurations would achieve a 10.5:1 ratio. Use of Screamin’ EagleŽ spark plugs P/N 32320-91 when flat-top pistons are used or P/N 32321-91 with high compression pistons is recommended. Best performance can be obtained by combining with one of HarleyŽs Screamin' EagleŽ valve spring can accommodate up to .575" valve lift camshaft kits. Heads are machined to accept Compression Release P/N 29298-02.
* Caution: Screamin’ EagleŽ Adjustable or Perfect Fit Pushrods are required for installation. Do not use high compression cast pistons with Screamin’ EagleŽ Twin Cam 88™ Performance Cylinder heads. Failure to comply may result in engine damage. For Race Application Only.
fenmore
Softail Parts
Apr 15, 2018 02:08 PM
cjm8806
26
Dec 3, 2016 10:59 PM
jlmillsjr
Engine Mechanical Topics
Dec 9, 2014 10:08 AM
cjm8806
Mar 10, 2009 02:10 AM
dozerdogue
Mar 11, 2008 10:12 PM
