103" bag 'O' marbles
Old Jul 26, 2010 | 06:58 PM
SLider McGee's Avatar
SLider McGee
Default 103" bag 'O' marbles
Pro help need please
I have just gone fron a 88" stock to a 103" build on an '03 fatboy and the excessive noise is driving me nuts.
At start up everything is solid and quiet; on the interstate it has excellent power and quiet throughout the entire range.
It's after it has heated up and at idle at the light that the noise drives me nuts(Oil tank is so hot you can't touch it).It sounds like it is between the lower case and valve train on the left side only and is insanely loud.
Sounds like a ratcheting bag of marbles(couldn't describe it better lol).
I have listened to several other builds and i know they can be rather loud, but this is ridiculous.
Being the novice to mediocre mechanic that i am any and all input on this matter would be greatly appreciated.
Here is the build:
4 3/8 SE stroker
Flattops
Fueling reaper 574 cams
Fueling solid cam gears
HD b lifters
Fueling pump
HD adjustable pushrods
SE camplate
Beehive springs
10 litre heads and induction (Ken Weber) port polish blah blah blah
biggie valves
Hooker step tuned exhaust - baffled
new shoe on primary chain
SE Pro tuner
Mobile 1 Syn 3 20/50
Thanks Guys,
Slider
Old Jul 26, 2010 | 08:58 PM
Kingofcubes's Avatar
Kingofcubes
Get something so you can see how hot the oil is getting, check the lower end for sumping, the oil bag for foaming oil, and report back. When it gets hot is the power down?
Old Jul 26, 2010 | 11:48 PM
SLider McGee
Hey King,
She powers through strong 2100 thru 6000 with no issues at any heat range
no loss anywhere - even on extended rides
Will check as advised and post back to you -thanks again
Old Jul 27, 2010 | 09:03 AM
djl's Avatar
djl
too much lash in cam gears?
improperly adjusted pushrods?
valve spring retainers making contact with rocker box cover?
lifters leaking down?
sumping?
You didn't mention oil pressure: how is it? Where exactly is "between the lower case and the valve train on the left side"?
What is the piston to cylinder clearance?
How hot does the oil get?
You could be dealing with more than one issue.
Old Jul 28, 2010 | 09:05 AM
Kingofcubes
I would get an oil temp dip stick, sounds like piston noise from super hot oil. What oil are you running?
Old Jul 28, 2010 | 09:17 AM
Old Gunny's Avatar
Old Gunny
Remnember the oil tamk will be too hot to touch when really warmed up.
I barely touch with the back of my knuckles and then say, yep all warmed up. 200-220 degrees is HOT to the touch.
I am in the camp that says the stock type lifters are not designed good enough for even stock HD engines. Why I run Woods after chasing noise for two years just like that.
My sound, using a long bladed screwdriver to track down, was at the top end. But it was the lifters causing all the top end rattleing .
Old Jul 28, 2010 | 10:02 PM
SLider McGee
Thanks again for the responses gentlemen
King, I'm running mobile 1 syn 3 20-50
Doesn't sound like lifters but wanting to change to woods anyhoo
have done a comparison with the riders I'm with and my oil tank is sizzling
will check all fluid temps and get back to you
DJL, no contacts with springs on rocker boxes
good on the pushrods and no sumping
I will open it up and check cam gear lash
Old Jul 28, 2010 | 10:08 PM
SLider McGee
King, no loss of power even when hot - Same HP and TQ
Old Jul 29, 2010 | 07:25 AM
Kingofcubes
May want to try straight wt dino oil, say 50 or even 60 wt. Have seen this work much better with quieting and cooling down engine.
Old Jul 29, 2010 | 11:08 AM
Old Gunny's Avatar
Old Gunny
I'm running a Jagg cooler. One of the side mount 10 row. Oil temp down here in SE Texas with 95 out, gets to about 210 degrees on the I-10. With 20-50 Amsoil.
Untill I change to Woods lifters I had bought 4 Qts of Redline 20-60. Still think about it now and then, at least for the rest of the Summer. Just out of curiosity, cause things are nice now..
