It's revision time
Old Aug 21, 2010 | 03:44 PM
Bad Disposition's Avatar
Bad Disposition
Default It's revision time
The friendly neighborhood CHP displayed the Reds and Blues yesterday. He stated the D&D with performance baffle was a little loud tell me something I did not already know.
He slapped my hand and said to put a muffle on it. I knew it was just a matter of time so it’s time to consider a few changes and play again.
Currently Running:
103 CI with 10:5:1 Cp pistons, heads are ported and worked, (Intake CFM= 262.5 Exhaust CFM =233.4), 40mm head gasket, Woods TW400-6 .650 lift cam, Wood Lifters, S&S Pushrods, 50mm SE throttle Body, D&D Fat Cat with performance baffle, Power Commander III, and Performance Machine High Flow Air System.
Current Dyno Numbers:
STD smoothing:1
Max power 110.40
Max Tq 116.73
I am considering
Boring to 107, raising the compression level one step up from 10:5:1, using the heads noted above, dropping to a Tman .625 cam, Axing the power commander moving to a TTS, keeping the Fat Cat, only if possible install a Supermeg Supertrapp to quiet it down to street legal noise levels, and new tune.
I do not like the tap tap that the woods produces… “I know I was told”…. as a note * Woods lifters did not eliminate all of the top end noise produced by the Woods’…just a little.
If anyone knows of a better muffler system for California, one that will attached to the Fat Cat Header let me know. I do not want to decrease my numbers, just decrease the loudness, and yet still have great sound
My questions are:
With the new setup, will both the exhaust note and valve train noise be reduced?
How much of a change in numbers either positive or negative may I expect…just an estimate or an educated guess is all I am looking for.
Old Aug 21, 2010 | 04:57 PM
beaureed445's Avatar
beaureed445
I don't know if I'd re-bore to a 107". Why not just try swapping cams (since you don't like the tap tap), and changing to a Fatcat Louvered Baffle? And yes, I'd definitely re-tune with a TTS over the PCIII.
Old Aug 21, 2010 | 09:17 PM
Bad Disposition
Will there not be a difference in the numbers between a 103 and 107? For instance, my 103's 110/116 vs a 107's 120/+??
Not that the numbers realley matter on paper. I guess what I am trying to get an idea about is, if I jump to a 107, drop the cam size, and switch baffles, will i gain power, lose power, or maintain my current numbers, and if so how much either way.
BD
Old Aug 22, 2010 | 01:19 PM
beaureed445
When my Softail was a 103", I wanted more power. At the time, I wasn't looking to split cases to go larger. So, I called around to a BUNCH of builders, who all said the same thing- "not worth it." They all said that I'd only gain about 4/4, and it wasn't worth the $$$ spent for the minimal gains.
mikestrikes
May 23, 2010 12:34 PM
Bad Disposition
Feb 19, 2010 12:45 PM
dr
Jul 6, 2009 12:34 PM
Lopoetve
21
Feb 26, 2009 03:26 AM
TakeNoCrap
53
Apr 3, 2008 12:25 PM
