Carb problems?
BTW...I also checked the petcock according to the manual and it seemed ok. so i think i can rule that out...
OR..... another thought that just hit me....
if the complete DJ kit is in there, the needle is adjustable, you could try raising the clip a notch or two, leaning out the midrange, which seemes to be where you are fouling plugs........
K.
Set your mixture screw about 2 turns out to start. With the motor warmed up and idling, turn the idle down using the idle screw. Turn the mixture screw in until the idle starts to slow even more, then turn it out until you get the highest rpms, but no further than that. If the idle is high, turn it back down using the idle screw and repeat the adjustment with the mixture screw.
Your goal is to have the mixture screw open only far enough to give you the highest idle rpms and if you turn it in even a quarter turn, the idle slows (you may need a tach to see it). Your desired final idle rpm can then be set with the idle screw.
If I move the e-clip up closer to the top it should lean it out a little right?
If the washers were in between the needle clip and slide(raising needle),sounds like the PO was trying to richen up the carb.
And BTW,its hard to concentrate with the Avitar you have!
and so are you, move the clip to the 3rd from the top (flat end) the washers are there to keep the needle tight, from bouncing up & down, so the spring locater puts tension on it, you want the washers to be about flush with the top of the needle but not over, with my clip on the 3rd slot, I have 3 washers on top, you're almost there, don't give up!! so to re-cap, here's what I would do,
put in the 42 slow jet, start out 3 turns out on the mixture screw, put the needle clip on the 3rd slot, with 3 washers on top, and a 180 main jet, which should be plenty big because the instructions for my DJ kit for a TC88 says "use the DJ 180 main jet with an aftermarket exhaust, or airbox. with AM exhaust, airbox and cams, use the DJ185main jet."
leave everything else as it was and try this set-up first, if this don't work, we'll go another route.... similar to Murphdog's set-up which would be stock needle shimmed up (underneath the head of the needle) with 2 of those small washers you have, or un-shimmed sporty needle, 42 slow jet, stock main jet holder with a 180 keihin main jet, un-drilled slide, stock or DJ slide spring, the DJ spring is supposed to be softer, so the slide will raise quicker and sooner.
good luck and let us know how it works out,
Kevin.
Lost....
--EDIT--
I just took it for about a 30 minute ride, it seems to run great, more power than before and better response... The only thing is. When I take off from a stop light, I noticed when the throtle is just a hair off idle coming up in speed it seems to be just a little rough, (sluggish) just for a second. But after I pass that point it runs great. Any ideas on this?
Thanks
