gasket replacement
Old Aug 31, 2010 | 08:30 AM
im's Avatar
im
Originally Posted by cbaker1@farmersagent.com
its definatly the cylander head. occasionally i can feel a puff of air coming from the side of the cylander when first starting the bike.
May wish to consider and confirm leak.
The rocker covers(very top portion of motor) are a 3 piece set-up.
The rocker cover gasket set(rubber coated metal) is about $50 at dealer for the whole set.
This would be a common leak point and can be pin pointed to an oil drip and sometimes a recurring "low phish" noise.
I may have missed mention of mileage but by age alone it would be very common for rocker cover gaskets. Again the rocker cover would be more common than head gasket and much easier to address.
Old Aug 31, 2010 | 08:39 AM
im's Avatar
im
here is a link with picture from a forum member.
Raising the tank an inch or so and removing the front motor mount increases access.
Using a sears midget combination wrench set to fit a small cut of drop in allen piece also helps.
https://www.hdforums.com/forum/tech-...eplacment.html
Uncle Fuzzy
Engine Mechanical Topics
21
Aug 21, 2022 11:57 AM
Huskerjim
Feb 5, 2014 03:58 PM
natural gasser
Feb 17, 2013 12:41 PM
dirtbag1
EVO
Oct 25, 2012 06:03 PM
straydog13
Ironhead
Aug 19, 2008 09:44 AM
