accelerator pump adjustment
Old Sep 7, 2006 | 07:36 PM
hotrod351's Avatar
hotrod351
Default accelerator pump adjustment
where can i find out how to adjust my super e accelerator pump. i can see an adjustment screw above the pump rod on the left side of the acc. pump cam. seems like when i turn it out it increases the amount of fuel delivered. my plugs look perfect but when im doing 55 and it the gas it starts moving then if i let of the gas it will pick up speed. figured it needed more pump. any help on this. ive tried finding something online but could only find out the details for rebuilding it.
Old Sep 7, 2006 | 09:29 PM
pittguy's Avatar
pittguy
Default RE: accelerator pump adjustment
Turn screw all the way in yet not tight.Turn screw out a 1/4 turn at atime,rechecking throttle response,keep increasing till bike stumbles then go to previous setting.Road test to recheck settings.Best throttle response w/least pump travel equals best fuel economy.Road test usuing off idle tests and approx setting responses from each 500 rpm.Your intermediate and high speed jetting must be close for best results.Altering either jet may require readjusting accel settings.Your accel screw shouldve been closed off during jet checks.Good luck alittle patience is needed.
Old Sep 7, 2006 | 09:45 PM
hotrod351's Avatar
hotrod351
ill try that. i counted the turns in and its set at 2&1/2 turns out. does that sound like a lot.
Old Sep 8, 2006 | 07:13 PM
pittguy's Avatar
pittguy
It all depends on your build,thats probably close.Excessive black exhaust will tell ya.
Old Sep 8, 2006 | 07:34 PM
hotrod351's Avatar
hotrod351
thanks, thats what i found out. i finally found the instructions on S&S web site. it says about 2 turns is a good place to start. before that i found a site that said bottom it out and then turn 1/4 turn at a time. so i thought that being at 2&1/2 turns was way out there. i remember at the laughlin run my brother in law said i would puff black smoke once in a while. meaning it was set to rich. so ill just turn it in until it stumbles and falls then turn it out untill it feels good.
Buddy WMC
11
Apr 26, 2026 11:24 AM
fiveola
Shovelhead
17
Dec 6, 2012 07:49 AM
Sigsmaster
Aug 14, 2012 11:01 PM
2008FLHP
Jan 12, 2008 08:51 PM
joedirt
Sep 19, 2005 10:06 AM
