Recommendations
Old Sep 19, 2010 | 09:11 PM
mentor70's Avatar
mentor70
Originally Posted by Bad Disposition
Thanks guys,
Are S&S and R&R the only other case makers out there?
the MoCo has big bore Hi strength cases in there 2011 SE catolog. 599.00 msrp
Old Sep 19, 2010 | 09:16 PM
Bad Disposition's Avatar
Bad Disposition
Default Recommendations
Very well,
Thanks.
BD
Old Sep 19, 2010 | 09:43 PM
C-Cat's Avatar
C-Cat
the se cases aren't going to give you any more surface area to prevent weeping of the cylinders. they come with a 4.060 bore and will have to be bored to go 4.250 in this respect, no difference from the stock cases.
Old Sep 20, 2010 | 01:03 AM
Bad Disposition
WOW this is great!
On a stock case how much needs to be taken off to accomodate a 124 CI cylinder?
On the new case mentioned how much needs to be taken off to accomodate a 124 CI cylinder
Who can tell me how much surface space I actualley need to keep the cylinders from weeping?
If I use the stock cases, and bore them how much flat surface space will be left?
If I use the new cases mentioned and not have them bored, how much flat surface space will be left? If I need to bore the new case more, how much will it need to be bored and then how much space will be left to mount the gaskets.
I think with the use of O Ring gaskets and Flat Gaskets in addtion to crank and head relief valves, the risk of seepage is small.
Thanks for the info Wurk. I'll take the suggestion and run with it..
Old Sep 20, 2010 | 05:52 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
The OEM cases are absolutely 100% fine for any 4 1/8" bore cylinder application, Axtell, or S&S.
Can't even tell you how many we have bored. No problems whatsoever.
4.250"(4 1/4) is something different, as they can weep.
Scott
Old Sep 20, 2010 | 08:28 AM
Bad Disposition
Scott,
Will the new cases Mentor mentioned handle a 4.250"(4 1/4) bore without the possibility of having the cylinders weep or having the case expierence a stress fracture?
If not, I need a larger case, one that is bare as I have all the guts on order and or paid for, a case withmore meat. Any recommendations?
I know about S&S R&R and Delkron, I am not enthused about paying another $2000. I'll spend it but only if I have too.
This issue is causing the hair on the back of my neck to stand up and raise serious doubts it's starting to kind of suck.
BD
Old Sep 20, 2010 | 09:46 AM
Hillsidecycle.com
Sponsor
BD,
Have not had any experience with those crankcases yet.
If they are like the material used in an S&S case, then then they would be manufactured from 356-T6 aluminum. Very high tensile cast aluminum, almost like that of extruded bar.
Scott
Old Sep 20, 2010 | 09:50 AM
Hillsidecycle.com
Sponsor
Originally Posted by rob71458
4K on my 124 so far. No problems at all, unless you consider tire spin a problem.
Rob,
How has your bike been running, now, after you have had a "proper" tune put on it, from those fellows in Maine, vs the "Keystone Shuffle"????
Scott
Old Sep 20, 2010 | 09:57 AM
arealinvestor's Avatar
arealinvestor
Thumbs up
Scott,
BD
I could be wrong,but the cases Mentor mentioned are the same standard cases that come on the 96ci motor,only they come already bored to accept the 120ci bore(I think it's 4.060???).Bad, I'm not trying to tell you what to do ,but the 4.250 bore is a costly bore.It's either purchase new cases($2,000), or configure your 124 different.I would spend the $2000 differently if I was you.I still don't understand why your fixed on that bore.What are you going to do for the intake??? Are you going with the 58mm TBW, or you going to wait for the new 62mm TBW from SE???
Old Sep 20, 2010 | 10:34 AM
rob71458's Avatar
rob71458
Smile
Originally Posted by Hillsidecycle.com
Rob,
Scott
She's a runner!
jon loder
Engine Mechanical Topics
Jan 31, 2017 06:18 AM
UltraKla$$ic
Oct 7, 2009 09:42 PM
jeffwest5599
May 30, 2008 08:03 PM
mentor70
Apr 1, 2008 09:08 PM
74_ironhead
Ironhead
Oct 9, 2006 08:33 AM
