And... the 120 does NOT have an upgraded bearing either. If one is going to spout off facts... gets the facts correct. Or keep your self out of a post. Folks read these things and might take what YOU say as the truth and it is NOT. So STFU and stick with chrome and little blue lights.. That same bearing comes on EVERY engine MOCO sells since 2009, BOTH sides, too.
I would do a 95" in a heartbeat, best bang for your buck hands down. Nobody will leave you in the dust --trust me and great running bang for the buck. Wish I had my old 95' carbed motor its still running like a bear to my bud who I sold it to .....
I am a fan of T-Man Performance. I have seen some really good power come out of his setup's. I am still looking at doing a 95" kit from T-Man. I am looking at the "Stage 2 Street Eliminator Pro-Touring" kit... I think it is just under $2,000. They have a cheaper setup, for around like $1,800. You get heads, cams (Your choice), Wiseco pistons, gaskets, etc... But, you do have to send your cylinders out for machining, I believe. The Stg 2 offers around 110hp / 110tq (estimated). They have a couple dyno sheets posted, so check'em out. Hope this gives you some more options! Let us know what you decide!
I have done everything that everyone is talking about. went from 88" stage 1 to 95" head work compression........ wasnt enough. Recently completed an Axtell 107", bored cases, crank trued, more headwork(2" intake valves, 1.625 ex, milled to acheive 82cc) timken conversion, added a fatcat bbq, andrews 67g cams. Got over 1k miles on it just rode it accross the state. Gonna get it on a dyno soon I hope. By feel, its ALOT faster than my 95" motor, power is addicting, go as big as you can afford the first time around you'll save money and won't be wanting more as soon as if you stayed 95" only. I really should have went to a 117" but didnt feel like spending an extra $1400-2000 on this.
Really I guess any1 can be wrong then even your (_}_) Here it is straight out of the SE catalog on the 120R motor page 20
• Lefty high-performance crankcase output bearing..............But still not a Timken
So STFU 2 BIIIIIaaaach
I have done everything that everyone is talking about. timken conversion,
Really you had to have it converted to the timken the way some are talking in here you should have already had one. Why would you pay for something that wasn't needed. Or maybe someone doesn't know there head from their (_}_) and hey that could just be me. I guess
Someone set the record straight.........someone that we can all trust...... Hillside.....Scott?
Not gonna' take side here, but Timkens were used by the Moco, from back in the Panhead days,(1955-1968, OE # 9029, 1969-up-OE # 9028) 'till 2002.
After that, a large, heavy-duty roller bearing was used, and is common to both pinion and sprocket shaft.
The newer "leftys" look as though that the outer race is coated, and look identical to the non-leftys as far as we see, but nonetheless, we have seen some mighty powerful engines(S&S 116"s kits @ 135/135) run just fine with the OEM roller bearing set-ups.
That's my story, and I'm sticking to it.
Scott
Reason: bearing info
And... that literature is hype. Dude. The lefty in the 120r is the same as the one in an 09 or newer bike. Part number the same and when tore apart it's the same. The black one. Was a running change in 09 MY. Your blue light special doesn't have the newer bearing set.
Timkens came stock until, I thought 03, but Scotty says 02... no matter... the OP's bike HAS timken bearing on left side.. Roller bearings came along with cold forged cranks, as opposed to hot forged cranks.
I 100% agree with the roller is good enough.
So, I will be your bitch when you stop screwing up and giving bad info. What's the build on your bike, BTW. I HAVE a timken conversion right now, but next time may leave that alone.
Here we go. Another know-it-all. Maybe I missed it, but after reading matt816's post twice I still didn't see where he said what model year bike he has. How do you know he should already have a timken bearing in there when you don't know the years timkens were used or what year bike is being talked about?
