Exhaust Wrap
Old Oct 23, 2010 | 04:24 PM
djl's Avatar
djl
Default Exhaust Wrap
I hate heat shields so thinking of wrapping header pipes on a set of RH TDs but don't know anything about it and would like to hear from those that have been there, done that.
Would you do it again? Have you removed the wrap? How hard is it to remove/repair if damaged? How does it hold up to weather? How did you wrap around the clamps to the slipons, or were they left exposed?
Any do's or don'ts would be appreciated.
Old Oct 23, 2010 | 05:59 PM
peppi's Avatar
peppi
The metal fatigues and rots when you use the wrap. It's basically for racing to enhance exhaust flow.
Old Oct 23, 2010 | 06:02 PM
djl's Avatar
djl
Thanks, but I knew that much. Am interested in hearing from those that have installed the wrap on street builds. Like, how long does it take for the header pipe to "rot"?
I responded before the photo downloaded. How long did it take for that damage to occur? Why were the heatshields wrapped? Could that have contributed to the problem? I want to rid myself of heat shields and wrap the head pipes to cover up the three steps. I suppose I could have the head pipes ceramic coated and leave the steps exposed. Hmmmm, wonder how that would look?
Old Oct 23, 2010 | 06:19 PM
peppi's Avatar
peppi
They were V&H pipes and it took less than a year. The wrap holds in the heat and moisture and that's the cause of the de lamination of the pipes. The ceramic coating is a better thought for sure.
Old Oct 24, 2010 | 09:31 AM
07RoadHawg's Avatar
07RoadHawg
That's a good question. Seems like wrapping with the heat shields on would not be a good idea. I still don't understand the whole "trapping moisture" think. Pipes should run hot enough to burn off moisture, no?
Old Oct 24, 2010 | 09:55 AM
Lappierre's Avatar
Lappierre
6th Gear
as i cant see the pictures posted i will post the images of mine when i wrapped my V&H short Shots, the front header snapped off just below the head clamp and the rest of the pipe was delaminating all the way were the wrap touched the pipes,
they hold water very very well as when stationary from riding in the rain you would dissappear in a cloud of vapour
broken header
you can see the the delamination starting here round the O2 sensor
Pipes 11months before hand
mind i do ride in the snow
Old Oct 24, 2010 | 12:16 PM
07RoadHawg's Avatar
07RoadHawg
I guess the main question djl posted was why wrap the heat shields too? Most people would remove the heat shields and wrap the bare pipe. Perhaps that was a contributing factor to the early failure of the pipe. I know a few people that have wrapped theirs and haven't had any problems in well over 2 years. Not saying that it will or will not cause pipe failures, just an observation on your particular case.
Old Oct 24, 2010 | 01:20 PM
Lappierre's Avatar
Lappierre
6th Gear
I wrapped bare pipe on a metric and issues similar to my bob, the pipe plastised and started to deform, mind I do live a wet climate which possibly doesn't help
RB racing had an article on their site which explains the whole process better than I can
Old Oct 24, 2010 | 02:52 PM
Lappierre's Avatar
Lappierre
6th Gear
We also figured after the barepipe failure/deformation that wrapping the shields may have helped stop the issue by adding and air stream as minimal as it may have been but nope
Old Oct 25, 2010 | 10:24 AM
djl's Avatar
djl
I checked the RB Racing website but couldn't find the article you referred to. Can you provide a link to the article?
