Low idle
Old Oct 26, 2010 | 09:23 AM
monk's Avatar
monk
Stage II
Default Low idle
When I first start my bike, a fuel injected 99 eg classic, the idle is about 1k. If I blip the throttle, it drops to 400 to 500 rpm and remains there untiil I ride for about 20 minutes. After that, it idles at 800 to 900 rpm and stays there. The bike doesn't stall, but it shouldn't idle that low and I'm concerned. Can anyone help?
Old Oct 26, 2010 | 12:02 PM
ajayrk's Avatar
ajayrk
Roll the throttle until you can see the cold idle set screw. Turn it in 1/4 turn and check your idle.
Also remove the air cleaner and clean the throttle body with an spray cleaner. Be sure to put the straw into the two holes at the top of each throat, these are the idle bleed holes.
Old Oct 26, 2010 | 02:38 PM
Old Gunny's Avatar
Old Gunny
This might not apply to a 99 but you said FI.
On later bikes I know the start idle is set higher at first. It will hold higher, longer, till the throddle is moved. I try not to move the throddle, at first, long as I can. Let things settle down first so to speak. but only maybe 30 sec or so.
Old Oct 26, 2010 | 04:34 PM
monk's Avatar
monk
Stage II
Default Thanks ...
for the info. I can wait 5 minutes or more Gunny, but it doesn't matter. I'll try adjusting the cold idle.
Old Oct 26, 2010 | 05:19 PM
ajayrk's Avatar
ajayrk
It applies to all M/M injected bikes since 1995.
One other thing, pull the two fuses for a few minuets under the right side cover to allow the ECM to reset to the new setting.
Old Oct 28, 2010 | 08:25 PM
Papamte's Avatar
Papamte
On the end of the throttle shaft there is a plate that the IAC uses to control the idle speed. You can squirt some lube like WD40 on it and see if your idle speed improves. If it does then you may have the mini bearing in your plate needs replacing. You can find them at most any bearing supplier, and they're pretty cheap too. If the IAC senses any resistance it will back off and let your idle speed drop.
It's another thing to consider with thw MM systems. I had to change mine after it would keep losing the correct idle speed after I reset it several times.
Uncle
11
Nov 19, 2020 09:20 AM
skim1420
Oct 6, 2011 06:25 PM
gtojets
EVO
Feb 28, 2010 08:34 PM
timba3
Jun 9, 2008 06:20 PM
