Help: low idle / stalling
Old Oct 2, 2011 | 11:20 PM
skim1420's Avatar
skim1420
Default Help: low idle / stalling
I have an '01 Road King Classic. First year with EFI for FLHRCI. Some 25K miles on it.
When my bike isn't fully warmed up, it idles really low and stalls. When at a stop light I need to press the throttle a bit to keep the RPMs up.
This happens only when my bike hasn't fully warmed up. Now I live in Southern California, and it's been the summer - doesn't really drop below 60F. After the bike is warmed up, e.g. 30 minutes on the freeway, the idle is healthy and the stalls go away.
Also, when the EFI system does recognize properly that the bike is "cold", it will up the throttle in order to warm up the bike. Like first thing in the morning.
Suggestions?
Old Oct 3, 2011 | 06:21 AM
Bodean46's Avatar
Bodean46
My 01 Ultra does that once in a while. I pull the a/c and spray carb cleaner or Seafoam into the air bleeds (10 and 2 in upper part of throttle body) and start it up, hold butterflies open, hold rpm around 3000 and spray directly into throttle body. Usually takes care of the idle problem.
Old Oct 3, 2011 | 10:58 AM
carlgrover's Avatar
carlgrover
Sounds like you need to reset your cold idle. When cold, mine idles at 1,500 rpm. As it warms up, the idle drops down to 1,000 rpm.
Old Oct 3, 2011 | 11:05 PM
skim1420's Avatar
skim1420
How do I set my cold idle on an EFI?
Old Oct 4, 2011 | 10:54 AM
carlgrover's Avatar
carlgrover
This is how I did mine:
https://www.hdforums.com/forum/engin...m-systems.html
Old Oct 4, 2011 | 02:46 PM
skim1420's Avatar
skim1420
Thanks. I'm new to this. My bike doesn't have a tach - will a handheld tach do? Can someone recommend one that will work with my bike (01 FLHRCI)?
Old Oct 4, 2011 | 02:53 PM
skim1420's Avatar
skim1420
Also, a point of clarification just in case:
Warm idle is fine.
Cold idle seems fine too, at least immediately after starting. However, after a short time (by the time I'm on the road) the idle drops to problematic rpms, causing stalling.
Does this still sound like a straight up cold idle problem?
Old Oct 6, 2011 | 04:55 PM
skim1420's Avatar
skim1420
Bump -
1) Asking for recommendation on a hand-held tach, per post 6
2) Asking advice on whether this still seems like a cold idle problem, per post 7
Thanks.
Old Oct 6, 2011 | 06:11 PM
flhxkiller's Avatar
flhxkiller
That's a common issue that year, my old 01RKC did the same thing. Thats one of the reasons the 02 went to a Delphi fuel system. Forget what the fix is though, maybe Dawg will pipe in soon with the answer.
Old Oct 6, 2011 | 06:25 PM
slyder's Avatar
slyder
actually first year for EFI on an FLHRCI was 1999. Ive got one and its runs almost flawlessly. Alot of people hate the Magnetti Marelli.....I kinda like it. Now that Ive figured it out.
Uncle
11
Nov 19, 2020 09:20 AM
emperor wurm
Dec 8, 2011 10:08 PM
monk
Exhaust System Topics
Oct 28, 2010 08:25 PM
gtojets
EVO
Feb 28, 2010 08:34 PM
irishviking
Aug 19, 2008 03:48 PM
