Andrews 54N Cams
Old Nov 5, 2010 | 11:36 AM
djl's Avatar
djl
Originally Posted by 2005flstfi
Scott
How would that 1.725 SE rocker arm go in a 95" with SE flat tops, would I need to machine valve reliefs. & also how would the same rocker arm go with woods 6-6
Depends on pistons. You don't have to worry so much about the depth of the relief but the larger intake valve could strike the piston outside the relief. Always best to mock up and clay the heads for clearances. If necessary, an "eyebrow" may need to be machined outboard of the orignal valve relief or fly cutting the original relief to open it up and move it outward to provide additional clearance. Check the photos. The first illustrates valve contact with piston and the second illustrated opening up the valve relief to avoid that contact.
Attached Thumbnails Andrews 54N Cams-pistonstrikemarks.jpg   Andrews 54N Cams-relief_measurements.jpg
ChangedBagger
Engine Mechanical Topics
13
Mar 15, 2015 08:01 PM
Ryan8585
Apr 23, 2013 12:54 PM
jakerbaker01
11
Aug 31, 2011 07:15 PM
blown alcohol
Dec 10, 2007 10:21 AM
