Sudden onset backfiring
Old Oct 29, 2010 | 12:08 PM
lfmn16's Avatar
lfmn16
Default Sudden onset backfiring
2007 Softail, stage one, Vance and Hines Pipes, Spike air filter (can't remember who makes it, but it wasn't one of the cheap ones) 11,000 trouble free miles with all scheduled maintenance done at a dealer that I trust. Last mod was done about 1,000 miles ago - replace K&N air filter with the spike. I specifically asked if it needed to be remapped or dyno'd because of the replacement and they said no.
I went for about 150 mile ride last Sunday. About 120 miles into it I started to get backfire on deceleration (It's never happened before). It got worse and at about 145 miles the bike stalled at a stoplight. It started right back up and the last 5 miles home I had no more problems. I put gas in as I started the ride - high test at a station where I have stopped before. It was a sunny day and a route I ride often.
Any ideas? I'm going to take it out this afternoon to see if I have any problems.
Thanks.
Old Oct 29, 2010 | 05:42 PM
Old Gunny's Avatar
Old Gunny
Trying to think what might cause this. Gas at first, but then no, you covered that.
Maybe the IAC stuck closed. This is something that could happen anytime, cause it happenes sometime.
I think this would cause a rich condition, slowing down, (zero throddle backfire) and even stall you out when stopped or at idle.
And something that could go back to working.
Clean it out, use carb cleaner not brake cleaner. I like to spray some silicone spray into the inlet hole when running to give it some lubrication.
Brake cleaner run thru the combustiuon process exhausts Phosegene gas I read in AIM I believe it was. Seriousely ruin your day, at the least.
Old Oct 29, 2010 | 06:58 PM
asm481's Avatar
asm481
I'd be lookin' for something loose. Start with exhaust.
Old Oct 29, 2010 | 07:15 PM
peppi's Avatar
peppi
Aside from any engine problems in mapping, I would be looking for an exhaust leak that is allowing air into the system which would cause your problem on deceleration. Check the nuts for torque on the pipe flanges on the head pipes.
Old Oct 29, 2010 | 08:12 PM
Slikroc's Avatar
Slikroc
My '05 did something similar. It was the internal fuel line, ruptured and leaking.
Old Oct 30, 2010 | 09:15 AM
95custmz's Avatar
95custmz
Check manifold seals and for any faulty sensors.
Old Oct 31, 2010 | 12:05 PM
lfmn16's Avatar
lfmn16
Thanks to everyone for the suggestions. It's not doing it anymore, so I'll have to see how it goes.
Old Nov 1, 2010 | 03:19 AM
95custmz's Avatar
95custmz
If it happens again,check your crank position sensor.The backfiring sounds like a dead-giveaway.
SGT Rock TN
Jan 23, 2014 04:11 PM
dan z
Nov 26, 2012 03:38 PM
nopetrol
Mar 25, 2012 09:18 PM
Beercan321
Jun 30, 2011 02:53 PM
sportster2009
Oct 22, 2009 07:05 AM
