Timer cover
Old Jun 23, 2005 | 10:42 PM
MDQ1's Avatar
MDQ1
Stage I
Default Timer cover
First let me say hello and thanx for information that I have read.
My question is wether there is a trick to getting the screws out of the timer cover. I just seem to be twisting the T-15 torx bit.
Thanx
MDQ
2003 Softail Deuce
Old Jun 23, 2005 | 10:45 PM
John TN's Avatar
John TN
Default RE: Timer cover
Not sure of the correct size bit, but Harley puts some loc-tite on at the factory that is damn hard on screw removal. Sometimes you have to heat the screws to get them out or use an impact wrench or both.
John TN
Old Jun 24, 2005 | 12:15 AM
Kess's Avatar
Kess
What is the proper method to heat the screws?
Old Jun 24, 2005 | 02:44 AM
Scout's Avatar
Scout
If you are twisting the torx, they are way over tight. They are only supposed to be 7 foot pounds.
The loctite breaks down at 285 degrees. If you have to go to this extreme you don't want to apply flame right on your cover, so what I do is put the torx into the screw head, and then with a propane torch apply heat to the torx. When you get them out, replace them, since the threads are probably stretched.
Good Luck
nuttbaggerr
Mar 20, 2020 08:02 AM
GoFastr
Oct 24, 2014 02:47 PM
jp28
Jul 3, 2012 08:16 AM
Cloud09King
Sep 5, 2007 09:42 AM
SportyPig
Aug 14, 2006 09:28 PM
