Derby cover fasteners
Old Apr 17, 2015 | 03:15 AM
nuttbaggerr's Avatar
nuttbaggerr
Default Derby cover fasteners
Derby cover fasteners (allen or torx): Torque down dry, with anti-seize, or with medium thread-lock? Why chose one I er the others?
The reason I ask is because of some of the stories I've been reading about these fasteners breaking or rounding off at the head. Besides being over-torqued (by someone, somewhere), or using the wrong-sized bit to install/remove, why else are theses fasteners so difficult to remove by some? If it was torqued properly in inch-pounds, what causes these bolts to seize up? And what csn be done to prevent them from seizing and breaking?
Old Apr 17, 2015 | 04:15 AM
Dguy's Avatar
Dguy
Some guys go to the allen over the torx but the key is to make sure you are using the right size torx! They don't realize it's the wrong size until they round one out.
Old Apr 17, 2015 | 04:19 AM
shadowchrome's Avatar
shadowchrome
I use anti seize on mine. Dissimilar metal corrosion is the issue.
http://www.bracketsandbolts.com/resources.php?id=118
Old Apr 17, 2015 | 05:11 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Yep. T27 is all but evil, being so close to T25. Weird inclusion in the size range. ...T15, T20, T25, T27, T30, T35...
There is also the T47, but I hardly ever see that. Run into the T25-T27 debacle regularly.
Old Apr 17, 2015 | 05:34 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
Torx, anti seize, correct tool, just snug.
To over tighten these is just crazy.
Old Apr 17, 2015 | 05:53 AM
lp's Avatar
lp
Before attempting to loosen those, run the motor until hot, and use a good quality T27, and you'll never have a problem cracking those loose.
I do change them over to Allen after because that's what's all over the bike anyway and it's just easier.
Never had to look for a "good quality" properly sized allen before. It just do's it or it dont's.
Old Apr 17, 2015 | 07:19 AM
95ci springer's Avatar
95ci springer
Switch to Allen. Better for torquing down and they look better. I put them in dry.
Old Apr 17, 2015 | 07:53 AM
bagga's Avatar
bagga
go to a hardware store and get some stainless allens. put some oil on the threads, screw them in just so they're good and tight.
Old Apr 17, 2015 | 08:03 AM
foxtrapper's Avatar
foxtrapper
A torx head is stronger than an allen, all other variables held constant.
That said, hardware store stainless allens don't rust, and are pretty darn strong. Personally, I've been prone to switching things when I remove them for those reasons. Especially on the smaller chrome plated allen screws, which get damaged and then rust when you use an allen key on them.
Old Apr 17, 2015 | 08:08 AM
texaswiz's Avatar
texaswiz
The problem with the torx screws is usually because some asshat mechanic in the dealership uses his air gun to tighten the living **** out of the derby screws. Then, when the owner tries to remove the screws he either uses a worn torx bit or probably an undersize bit and the next thing you know, the head is rounded off and the name calling begins.
Why in the hell the factory doesn't just put allen screws in there in the beginning has been a mystery to me forever. They definitely could make this more user friendly...if they really wanted to.
