Time-Sert Inserts Any Good??
Old Dec 20, 2010 | 11:13 AM
BlackFatBob64's Avatar
BlackFatBob64
Default Time-Sert Inserts Any Good??
Guys,
This is my first thread here so please go easy on the newbie!
I have been in and out of the cam box on my 08 dyna several times now installing cams and the like and the 1/4-20 threaded holes for the cover and cam plate are showing signs of wear.
I'm thinking of redoing all of them with time-serts so i have steel on steel bolting surfaces.
Any opinions or experience good or bad would be greatly appreciated.
Old Dec 20, 2010 | 12:32 PM
radattack's Avatar
radattack
5th Gear
Time serts work very well, but i dont think i would do it in this case. i would only do them if completely necessary. i had to do one in the head of my bike for my exhaust bolt and it worked great. i have heard of people drilling crooked and then the time sert doesnt go in straight. i personally wouldnt take the chance of doing all of them if you still have a good bit of threads working in the holes.
Old Dec 20, 2010 | 12:40 PM
BlackFatBob64
Good point! I probably should make up a guide block before I go to town with the hand drill. Probably save me the cussing of a broken tap, too! 1/4-20 is pretty small and taps can break like glass!
Old Dec 20, 2010 | 12:51 PM
djl's Avatar
djl
I would run a thread restoring tap, not a new tap for cutting threads through all, or just the worst offenders and install a stud with some red loctite. Less work, no drilling issues and a final solution.
Attached Thumbnails Time-Sert Inserts  Any Good??-cam-cover-nuts.jpg   Time-Sert Inserts  Any Good??-cam-cover-stud-spec.jpg
Old Dec 20, 2010 | 01:25 PM
BlackFatBob64
Now I like that! And I don't have to search all over for a time sert dealer, too
Thanks!
Old Dec 21, 2010 | 11:29 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Originally Posted by BlackFatBob64
Guys,
Your local NAPA store should have Heli-Coil Brand Repair Kits on the shelf.
Installed correctly, the'll work like a champ, and will actually be stronger than the parent material.
Scott
Ironbyrd81
Apr 30, 2019 08:39 PM
Riffraff123
Engine Mechanical Topics
Mar 24, 2016 09:42 AM
davidnewtonparr
Aug 15, 2013 09:37 AM
sctrucker
Jun 15, 2012 09:14 PM
snoeman
Shovelhead
Oct 2, 2007 02:10 AM
