I think the OP has a stock 103" if that make's any difference ??
Doesn't make any difference when comparing charts; just looking at the torque under the curve.
R103, the below link is will show a dyno chart for a stock 103" with a cam only upgrade to the SE204. Pretty impressive and, I believe, similar to what you would see with the 48 with the exception that the 48 should hang in a while longer.
