ev27 upgrade question!
Old Feb 25, 2011 | 03:12 PM
Silver GT's Avatar
Silver GT
Stage III
Originally Posted by grbrown
I think you'll find the EV27 predates those rockers!
what do you mean predates????
both of the items fit an EVO
Old Feb 26, 2011 | 09:28 AM
inverse121's Avatar
inverse121
Originally Posted by Silver GT
has anyone tried an Ev27 with 1:1.675 ratio roller rockers.
I'm looking at doing this but i am concerned about problems such as the valves hitting the pistion or not having enough spring movement.
can any advise?
thanks in advance
Yes, I have, but you need to check your clearances, you cannot assume it will work for you.
I wouldn't be as worried about valve to piston clearance as I would about valve to valve, spring bind and retainer to guide clearances.
So check your clearance, set your heads up correctly and you won't have any problems.
Old Feb 26, 2011 | 09:41 AM
DeweysHeads's Avatar
DeweysHeads
Retainers hit the seals at .540 with stock springs.
I cut the guides and use late model beehives, 140# on the seat. Have done many EVOs with the EV27. Dynamite performance.
Old Feb 26, 2011 | 06:23 PM
Silver GT's Avatar
Silver GT
Stage III
I have calculated that the total of .510 so the stock springs and guides should be okay.
so if i dont have valve to valve clearance issues I should be fine.
Would it make much difference to performance....or would it not be to noticable.
thanks for you input guys....really appreciated.
Old Feb 27, 2011 | 08:50 AM
DeweysHeads
Actually .525
Check for clearance in the top of the pushrod tubes as they get the added ratio by shortening that lever, thepushrod end of the rocker. Depending on the adjustable pushrods you use they potentially could hit.
Mill the heads .070 or you will see not much noticeable increase in power / torque
Old Feb 28, 2011 | 04:09 AM
grbrown's Avatar
grbrown
Wink
All I mean is that the EV27 has been around a very long time. I fitted one to my bike 20 years ago, before we started playing with different ratio rocker arms. It seems to me mixing up an old favourite cam with modern rocker thinking, which may not work as well as with a different modern cam. That's all!
Old Mar 21, 2011 | 09:09 AM
blair's Avatar
blair
I just installed the Andrews EV27 on my bike (1996 FXDWG) last weekend with a new Torington bearing( make sure you check the cam end play) Andrews recomends .010-.015, mine was .013 , I used a .55 cam shim. Adj pushrods and a Dyna 2000 ignition. Wow it works awsome .A very good cam selection for sure.
wtsamatta
Engine Mechanical Topics
11
Oct 28, 2016 05:33 AM
JKSHYT
Jan 21, 2014 04:17 AM
Harleyriding77
May 24, 2011 05:30 PM
jhill2209
May 3, 2009 06:42 AM
riden2low
EVO
Apr 13, 2007 02:23 AM
