Low speed miss
Old Feb 3, 2011 | 11:29 AM
ro.co3's Avatar
ro.co3
6th Gear
Talking Low speed miss
My 2006 heritage has a low speed miss or light bucking at around 10 to 15mph in first gear. It will do it in second also if I'm going slow enough. I'm not talking about slow speed chug (going to slow for the gear). It Idles great, pulls good once out of the low end speed and runs great in the mid and high ranges. I put a new set of Harley plugs in and had the stealer in stall the new style fuel injectors. (06 had a problem with injectors) I've also run some fuel injector cleaner and so for nothing seems to solve the problem. So any feedback would be appreciated.
Old Feb 3, 2011 | 11:41 AM
ro.co3's Avatar
ro.co3
6th Gear
I should have mentioned I pulled the codes with nothing showing, the dealer pulled them also with nothing. Thanks for looking.
Old Feb 5, 2011 | 03:01 PM
ro.co3's Avatar
ro.co3
6th Gear
Am I in the wrong place to get any feedback?
Old Feb 5, 2011 | 06:37 PM
KumaRide's Avatar
KumaRide
Maybe you have a hole in the fuel line? Very common. Can be very intermittent and does not always have the same symptom. Google harley pin hole fuel line.
"So when diagnosing problems that you can not seem to get rid of, one final test is always to run the bike down to the point where the fuel lite is on, then open the gas cap and listen for a high pressure fuel leak."
Their is another way to test with removing the fuel pump fuse. Cant remember exactly how. Search in the softail forum also and you will find info.
KumaRide's Avatar
KumaRide
Old Feb 6, 2011 | 06:50 AM
ro.co3's Avatar
ro.co3
6th Gear
Thanks for the feedback Kumaride. I,m beginning to think its running lean at low speed so I ordered a tuner. I will try the test you posted for the fuel line. At this point I have an open mind. Thanks again.
Chucklesgolf
General Topics/Tech Tips
Jul 31, 2023 12:37 PM
jimfount00
Nov 4, 2015 05:40 PM
mattyballgame72
Harley-Davidson Street
11
Jul 20, 2015 01:41 PM
bigpaw
May 14, 2012 08:10 AM
gunmetal
Sep 12, 2009 08:51 PM
