Head Gasket
Old Feb 6, 2011 | 11:57 AM
JimmieJack's Avatar
JimmieJack
Default Head Gasket
I'm changing out the cam and decided to change the head gasket too.
When I pulled the head there was a lot of old gasket material left on the top of the cylinder. What is the best way to clean this up. I don't want to damage the top of the cylinder or bottom of the head. I know if I don't get it right I'll be pulling all apart real soon.
I have a Dremal Tool and some polishing wheels and thought about trying that.
BTW - I'm actually doing this project right now - so any help would be greatly appreciated.
Jimmie
Old Feb 6, 2011 | 12:56 PM
dawg's Avatar
dawg
I use a razor blade and some gasket remover and scrape it evenly. I also would scrape the carbon off the pistons the same way. An .030 head gasket would give you a small bump in compression, I assume that's what you are doing?
Old Feb 7, 2011 | 01:05 AM
JimmieJack's Avatar
JimmieJack
Default thanks
Thanks. In the heat of the moment - I overlooked the obvious.
Jimmie
Old Feb 7, 2011 | 05:19 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
We glass bead both the cylinder base, as well as the cylinder head gasket surface, as that leaves us with a very uniform clean surface, when we reassemble.
Scott
Old Feb 7, 2011 | 08:16 PM
N-gin's Avatar
N-gin
I wouldnt use any kind of wire brush or scrapper on the piston top. All that does is provide more groves to attract more carbon. I would use Sea Foam and a cloth. This way no carbon chuncks or scrapings from the piston get stuck between piston an cylider.
As for the head and cylinder I use a popsickle stick. For heavy material I use a soft rubber bristled wheel.
Old Feb 7, 2011 | 08:24 PM
miacycles's Avatar
miacycles
3-M makes a chemical gasket remover that softens up the gasket and makes it much easier to remove. It may take more than one application for stuborn sections.
drhooligan
Engine Mechanical Topics
Nov 11, 2016 05:47 AM
natural gasser
Feb 17, 2013 12:41 PM
stlboarder
Dec 23, 2010 10:46 PM
rivercityslim
EVO
Nov 16, 2009 02:50 PM
straydog13
Ironhead
Aug 19, 2008 09:44 AM
