O2 sensor
Old Feb 18, 2011 | 08:02 PM
Papi's Avatar
Papi
Default O2 sensor
Can an O2 sensor be added to a 2004 FLSTFI? If so how labor intensive is it and how much do you think it would cost? What are the benefits of this kind of mod?
Old Feb 18, 2011 | 08:48 PM
$tonecold's Avatar
$tonecold
Yes. If you change you ecm to a Thunder-Max, Daytona Twin-Tec, and there are probably others. Revolution Performance offers their EMS for all Twin C ams, but for some reason the '04 models have to install an ECM from an '05 model. You should call them and discuss this with them since they'll be able to explain this. The good thing about their system is you don't have to pay someone to dyno your bike and tune it. They'll even weld the bung in your pipes for a reasonable charge.
Old Feb 19, 2011 | 06:11 AM
Papi's Avatar
Papi
Whats the advantage of that kind of system over stock?
Old Feb 19, 2011 | 09:56 AM
$tonecold's Avatar
$tonecold
I guess it depends on where you live and ride. I live in Az. where the elevations vary greatly. O2's read the amount of oxygen in the air and adjust the fuel mix for that. On earlier models w/o O2's the MAP (manifold air pressure) sensor made the adjustment. O2's probably do a somewhat better job or all the auto mfg. wouldn't be using them. The other advantage to the T-Max or EMS is if you are planning some engine upgrades. They will allow you to adjust for them like the SERT, but you don't really have to dyno the bike or pay a tuner.
Old Feb 19, 2011 | 10:37 AM
Papi's Avatar
Papi
What does ECM, EMS stand for? What is T-max? Is it the same as the TSS master tuner? Will the TSS master tuner do the same thing? I live in Washington State, if I ride to eastern Wa it's a high desert. To get over there I have to ride over mountain passes.
Old Feb 20, 2011 | 12:39 AM
Bluehighways's Avatar
Bluehighways
The Society of Automotive Engineers sets the standards for Abbreviations and Acronyms in their document: SAE J1930 (There are a few thousand of them.)
Your HD Workshop Manual lists those Abbreviations and Acronyms that apply specifically to your bike in the Glossary/Appendix.
You can also Google the Abbreviations and Acronyms you are curious about and they'll usually show up that way.
Old Feb 20, 2011 | 08:28 AM
Fatsurf's Avatar
Fatsurf
2nd Gear
Default O2 upgrade
I was thinking about doing this one myself. U R right that you will need a new ECM (engine control module ie; computer) that is of the 05 and up design (I have an 06 FLHT) the new computers have the added capability to read the sensors and run closed loop. I bought the TTS and spoke with the designer, do some research there. Advantage is to operate in closed loop during most cruise operation, this gives the most economical AFR. Additionally U can auto tune the ECM volumetric efficancy tables with the TTS if you have O2 sensors, other wise you need a dyno with an AFR sniffer to get the tables spot on for your combo. With that said I programmed the calibration from TTS that matched my combo and the bike runs great ( way better than the dealer stage II download).
Old Feb 21, 2011 | 07:19 PM
Papi's Avatar
Papi
So how much do you think an ECM, O2 sensor (do bikes have on or two?) and wiring cost?
Old Feb 21, 2011 | 07:44 PM
KumaRide's Avatar
KumaRide
Can not believe no one has asked you why you want to do this? Is it because of the mtn passes you mention? I ride from 500ft to 9500 ft elevations on day rides through the sierra's and have absolutely no problems nor do any of the other bikes without o2's. As some one said, the MAP compensates for altitudes. The main reason for 02's are epa compliance.
If you want the bike to run better look into cams, a 2n1 and even a 95" kit. Or at least a stage 1.
Sorry, not trying to derail you. Just want to understand the reason for the expense.
Old Feb 21, 2011 | 09:44 PM
Papi's Avatar
Papi
It was something I had asked a local builder. Just me trying
to figure out cost vs benefit
My goal by the way is to install a k&n with a Screamin eagle
Back plate, python 2 into 1, Andrews 37N cam, SE cam tensioner
oil pump kit, Fueling lifter, S E quick change push rods.
I think that about covers it
