Question on adding SE-2 Slip on's with 95B Engine
Old Jun 28, 2005 | 05:06 PM
rtb388's Avatar
rtb388
2nd Gear
Default Question on adding SE-2 Slip on's with 95B Engine
I know I have seen this before but I am wondering if I need the race tuner when I install the Screamin Eagle Pro II Slip-on mufflers.
I have a 2005 15th anniversary Fatboy with the 95B engine. The dealer is telling me there are no remap downloads for 2005 and up and that I need the Race tuner kit, air filter, and put on the Dyno. With 4-5 hours labor for everything. Of course at a price of around 1200 bucks for everything. *cough*
Do I already have the Stage 1 air cleaner and fuel map on my bike? Can I just put the mufflers on myself and go?
Thanks in andvance.
Old Jun 29, 2005 | 01:47 PM
1550ccFatBoy's Avatar
1550ccFatBoy
Default RE: Question on adding SE-2 Slip on's with 95B Engine
Yes, you have the Stage 1 from the factory. Try this link, this should help you on the remap situation. https://www.hdforums.com/m_24488/tm.htm
Old Jul 9, 2005 | 10:07 PM
HDF Tech's Avatar
HDF Tech
There are downloads for the 05 bikes. They are different than the ones for the 03 and back, 04&05 use a different map because of a faster ECM. Ask him if he has a digital tech (like a laptop) they contain all the downloads.The 06's are going to be different again.
Sounds like the dealer wants to make some $$$
If you do decide to go with the TFI/DFO, you would need the stealth model so it does not set a code.
There's always the option of a TFI/ DFO and you can richen it up yourself. They work well and are easy setup.
https://www.hdforums.com/m_64814/tm.htm
http://www.shopsprite.net/~easternp/...roducts_id=103
03nighttrain
2014-2024 Touring Models
22
Feb 14, 2019 02:04 PM
HipPhatCat
Oct 4, 2012 01:06 PM
sonofthunder
Jun 26, 2009 02:13 PM
Garrison1383
Mar 22, 2006 03:34 PM
IU_Booger
Aug 14, 2005 10:16 AM
