88 Twin - Andrews 21 or 26?
Old Mar 10, 2011 | 09:32 AM
simpkinst's Avatar
simpkinst
Default 88 Twin - Andrews 21 or 26?
Well, I am swapping cams here in my '06 FLHX and have most of the parts needed. I have purchased the SE Hydro Cam Tensioner Plate upgrade kit (which includes oil pump) and adj pushrods. Have all gaskets needed.
All I need is the actual cams to get this completed before the snow melts. Struggling between the Andrews 21 and 26 cams. This is a touring bike and my wife rides with me about 40% of the time so low end is crucial.
I am leaning towards the 21, but Andrews literation mention for 2-up go with the 26 - but also state its for 88-95 ci engines. I assume the 26 will not come to life w/o the 95 upgrade.
any thoughts/experience?
Old Mar 10, 2011 | 10:25 AM
djl's Avatar
djl
Originally Posted by simpkinst
Struggling between the Andrews 21 and 26 cams. This is a touring bike and my wife rides with me about 40% of the time so low end is crucial. I am leaning towards the 21, but Andrews literation mention for 2-up go with the 26 - but also state its for 88-95 ci engines. I assume the 26 will not come to life w/o the 95 upgrade.
You really can't go wrong with either cam. If you don't see 4500rpms very often, the 21 is the right cam; particularly with two up riding. The 21 intake closes 5* earlier than the 21, shorter duration with about the same TDC lift. The earlier close means higher corrected compression and that equals torque. The earlier intake close and shorter duration move the curve to the left which is where you seem to want the power.
Old Mar 10, 2011 | 04:08 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
When stepping up to that decision, we suggest the 26, as it'll be a GREAT gain now, and if you ever consider going to 95-98"s, with a good head, and perhaps a 1.725 rocker arm, absolutely no problem whatsoever showing a client 100/100.
Scott
Old Mar 11, 2011 | 09:02 AM
simpkinst's Avatar
simpkinst
Scott
Scott -
I never thought of that....95 is possible a few years down the road.
great advice.....as usual.
Brewser80
Mar 10, 2016 03:50 PM
Gunny20
Engine Mechanical Topics
Apr 7, 2015 06:59 AM
Oldfart666
Jan 21, 2011 10:21 PM
ssharley
Sep 17, 2009 12:49 PM
allaco
Sep 7, 2009 08:30 AM
