Cam recommendations.
Old Mar 17, 2015 | 01:37 PM
Gunny20's Avatar
Gunny20
Default Cam recommendations.
I have a 2000 95" Roadking with 203 cams and R&B 2-1 blackhole exhaust. I need a better low-midrange cam for 2 up riding, Suggestions please. I will not be doing any other mods.
Old Mar 17, 2015 | 03:12 PM
djl's Avatar
djl
Unfortunately, your cam choices are limited to cams with lift no greater than .500" because the early valve springs won't accommodate more lift than that. Two cams that would work are Andrews 21 and S&S 509.
Old Mar 17, 2015 | 05:05 PM
Gunny20's Avatar
Gunny20
Thanks DJ. I guess I'll save up for heads
Old Mar 18, 2015 | 08:49 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Not only that but your exhaust is not made for low end torque.....
Old Mar 18, 2015 | 01:02 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Yes, and yes.
Scott
Old Mar 23, 2015 | 07:05 AM
wheelspin's Avatar
wheelspin
Default 203 cams
I thought the SE203 cams were low/mid range cams. Could it be the exhaust and tune holding him back ?
Old Mar 23, 2015 | 04:19 PM
qtrracer's Avatar
qtrracer
The exhaust is fine if it is a 1.75" primary version. If it is the 2" version then he is running a far too large tube header.
Old Apr 7, 2015 | 06:59 AM
Gunny20's Avatar
Gunny20
Thanks for all the responses. My exhaust is 1.75 primary.
cdonis
Engine Mechanical Topics
13
Jul 14, 2014 08:00 AM
CYCLE1949
Ironhead
Feb 19, 2014 09:03 PM
cardboard
Exhaust System Topics
Oct 2, 2010 05:15 PM
fuelmoto
Aug 26, 2010 04:34 AM
voodoodrug
Aug 18, 2010 10:07 AM
