Starting issue - input sought
Background: Since last winter, when my bike started fine in weather down into the mid-20s, I have done the following: BDL Belt Drive, Andrews TW37B cams, Big Bore 95" kit.
After some 'head scratching' ... I deemed the following info relevant to the issue: the BDL affected two area--(i) primary drive ratio and (ii) starter gear ratio; compression ratio and cold cranking compression (PSI)
The above table captures the above-referenced data at the top of the table [the lower part of the table illustrates the effect of the change in the primary drive ratio] ....
So, CCC in PSI was raised from ~159 to ~171 ... an increase of 12 PSI ... though this is relatively modest (and the Compression Ratio is a 'mild' 9.2:1) ... however, due to the combined effect of the starter gearing ratio and the primary ratio, the stock 1.2 kW starter is trying to turn the motor over at 618 RPM vice stock rate of 424 RPM ... an increase of ~46% in engine RPM ...!
I am thinking the combined effect of trying to turn the motor over at higher RPM at ~8% higher compression is causing the system to balk and not start at low temps ....
Possible COAs (courses of action):
1. Higher output battery and heavier gauge cables (Check) ... on order
2. Retard the ignition advance and richen fuel mixture at start-up (Check) ... done (and seems to have helped somewhat) ...
3. Heavy-duty starter that can handle the increased load ...
4. Compression releases ...
... anything else ...?
I am a little up in the air as to the relative cost/benefit trade-off of COAs 3 and 4 ... I am inclined to do 4 in conjunction with either head porting or replacement with high performance heads with compression releases (and increase compression ratio a little to about 10:1) ....
If I were to follow that course, I expect that COA 3 would be OBE (overtaken by events ... or no longer necessary) ....
I am also posting this in a couple other places to hopefully increase the views and hopefully get some experts to chime in ....
THX in advance ...
R/
'Chop
First off you are the man knowing all this stuff. Hats off to you. Secondly to even want to start your bike in twenty degree weather makes you definitely the man in my book. Lastly I'd go buy the biggest steroid aftermarket starter and bolt that in and call it a day..compression releases are cool too....good luck.
I think the bigger starter motor is something of a 'band aid' ... but, if it works ....
I had been (am) contemplating heads anyway ... so ....
Of course in a few weeks when it warms up, the whole issue will be moot until the fall ....
your sugguestions are good i have a similiar ride with big cams big compression
starter ALL ***** RACING (lifetime warranty) 2.4kw
66 tooth ring gear
Hvy battery wire
that will do it!
I think 2.4kW may be a little overkill ... was contemplating 1.4kW or 1.6kW .... But, I may have to revisit the subject ....
I currently have the 66 tooth ring gear ... was considering going to 84 ... that would reduce the speed at which I am trying to turn over the motor (and reduce the burden on the starter motor) ....
R/
'Chop
