lifter question
Old Mar 29, 2011 | 08:38 PM
jerseydog's Avatar
jerseydog
Angry lifter question
just did a cam change and while getting everything together the lifter retaining clip fell off and the lifters slipped out of its bore, not sure if I reinstalled the lifter with the oil hole facing in and like a smacked a$$ I didn't check the manual for the proper installation procedure. I have everything back together and took in out for a little spin (flashed a fuel-moto map) bike seemed to be running really good. no major valve train noise ….i knwon I have a 50/50 chance that I got it right..but I'm not sure and that’s what bugging me.
My question is do I need to go back in and verify ? if so how hard is it to go back in through the valve covers? I did use adjustable push rods ,however I may have put just a little too much lock tight on the end caps
thanks for any and all help
Old Mar 29, 2011 | 08:47 PM
jerseydog's Avatar
jerseydog
sorry its a tc 96 and stock lifters' if that helps
Old Mar 29, 2011 | 08:54 PM
ml crisis's Avatar
ml crisis
Just went through the same exercise and as someone here pointed out to me, it doesn't matter. there is a recess around the lifter if you recall and oil will flow around it and fill either way.. The manual says hole in, when I took mine out they were hole out from the factory. You don't need to sweat it...
Old Mar 29, 2011 | 09:00 PM
jerseydog's Avatar
jerseydog
Default thanks ML
cool beans ! ...quess i can put the bolt cutters and the phone down thanks for the heads up... i was about to go back in
Mberlin74
Engine Mechanical Topics
Jun 27, 2016 07:20 PM
adm
21
Feb 19, 2016 11:56 AM
HardyHarHarley
Sep 3, 2010 09:00 AM
sneeky7374
Shovelhead
May 3, 2010 08:23 PM
rah002
Feb 5, 2007 01:19 AM
