removing power commander etc
Old May 10, 2011 | 12:16 PM
remerson's Avatar
remerson
Default removing power commander etc
Hello all,
I have a 09 Road King with a package from Fuel Moto (AC, PC-V, and Jackpots). I am purchasing a new 2011 SG and would like to move the PC-V and Jackpots.
My question is can I leave the S1 Air cleaner on the king, remove the PC-V, re-connect the O2 sensors and re-install the factory pipes? Would this cause any problems on the king?
I do not want to have to re-purchase the PC-V and Pipes if I do not have too.
Robb
Old May 10, 2011 | 12:20 PM
wurk_truk's Avatar
wurk_truk
Take the AC too and you would be good to go.
Old Jun 3, 2011 | 05:09 PM
fairlydangerous1's Avatar
fairlydangerous1
Pretty sure PCV is different for 10-11 bikes.
Old Jun 3, 2011 | 05:37 PM
wurk_truk's Avatar
wurk_truk
Absolutely correct. But the OP can sell his original PCV and that money should help somewhat.
Old Jun 9, 2011 | 03:49 PM
remerson's Avatar
remerson
Default Message from DynoJet Tech Support
Emailed Dynojet and asked about the PCV. Here is the question and answer:
Q:I have a question. I purcahsed a PC-V in 2010 for my 2009 FLHR 96ci and have traded the bike for a 2011 FLHX 103. I removed the PC-V from the old bike and would like to install it on the new FLHX. Someone told me that some PC-V would not work on the 2011's. is this true? Also I damaged one of the O2 terminators. Are these need for the 2011 FLHX 103? Thanks in advance
A:
The power commander that you have from your old bike will work on your 2011. You will just have to install the appropriate map for the year and engine size of your bike. As far as the O2 eliminators, they are not used on the 2011. I would recommend downloading the instructions for the 2011 from our web site. (www.powercomander.com)
Robb
<SPAN hwebmailCleaned='font-size:11.0pt;font-family:"Calibri","sans-serif";color:#1F497D'>
Old Jun 9, 2011 | 04:00 PM
remerson's Avatar
remerson
Been doing some research since I got the anser from Dynojet. I seems that there are 2 part numbers on their website. One for a 15-003 for a 2009 and 15-011 for a 2010-2011? Now I am confused. I also noted in the installation notes that installing the PC-V will put a historic code for O2 sensors not operational. Wonder if this will cause me a headache if I have trouble that needs to be covered under warranty?
Robb
Impala_ss
Jul 1, 2015 11:07 PM
IornStreetBob
Oct 22, 2014 12:26 PM
1931jamesw
Jul 2, 2011 04:01 PM
The Q
May 21, 2011 05:41 PM
mkguitar
Oct 18, 2010 05:37 AM
