pull starter
Old May 29, 2011 | 10:51 PM
WAYNES WORLD's Avatar
WAYNES WORLD
Stage IV
Default pull starter
How do I pull the starter from my 92 ultra?
WAYNES WORLD
Old May 30, 2011 | 08:47 AM
ajayrk's Avatar
ajayrk
You should get a service manual that illustrates the proper location of parts.
The short view:
Remove battery cable, remove the primary cover, remove the starter pinion gear, remove the two bolts holding the starter to the inner primary. Pull out the starter. You will need a long extension and a ball end hex socket or wiggler extension to reach the starter bolts.
PS
You still have trash under the needle in the carb. Did you replace the needle and check the float for proper position?
Rusty Axle
Shovelhead
Mar 14, 2018 02:18 PM
SHVLrules
Shovelhead
May 6, 2012 01:25 PM
SecondChance!!
Jul 5, 2011 10:03 PM
tsm1550
Jul 10, 2010 08:54 PM
timeout
Apr 12, 2010 10:10 PM
