Screamin Eagle Heavy Breather Vs. SE Ventilator Performance Air Cleaner Kit
Old Nov 25, 2014 | 07:43 PM
Wideglide1414's Avatar
Wideglide1414
Great info
Old Nov 30, 2014 | 06:35 PM
Puma NJ's Avatar
Puma NJ
Default Heavy Breather Elite
My 2014 CVO King came with the Heavy Breather Elite (a newer design I believe) and it doesn't amplify the valvetrain noise as much as some older CVO's. 110's make more noise than smaller engines so your WG might be quieter still. I haven't done my exhaust yet so I can hear everything and it's not a big deal. One cool thing is I can actually hear air being sucked into the thing when I blip the throttle.
Old Dec 3, 2014 | 09:28 AM
SleepyBagger's Avatar
SleepyBagger
Here is what I learned installing a Stage I upgrade on the Mrs. 2014 and a Stage IV on my 2015. The Stage Air Cleaner Kits use a larger diameter base plate to work with larger TB's whereas some filter elements offered use the stock base plate. There are many combinations of HD filter elements and after market elements to fit the stock housing and improve the volume of intake air, which in combination with higher flowing exhaust should have at least a Stage I download or better yet a dynometer tune to avoid running too lean thus creating a hotter running motor.
Old Jan 1, 2015 | 10:04 AM
HardyHarHarley's Avatar
HardyHarHarley
Actually, I believe the noise is the result of cams with larger overlap. That is, when both intake and exhaust valves are both open.
geezerglide09
Nov 27, 2014 11:03 AM
twincambill
Jul 2, 2014 02:31 PM
Arz135
Nov 4, 2013 11:20 AM
rhodry04
Apr 18, 2011 10:36 PM
Boxs
Sep 9, 2008 10:19 PM
