Vibration
Old Jun 28, 2011 | 10:24 PM
Ghosty's Avatar
Ghosty
Default Vibration
Hello all. I've got a quick question for those here that are good with engines. I have a 2003 road glide with a twin cam 88 engine. My engine vibrates real hard as it goes through 2000 rpm. It makes no difference what gear it is in it vibrates at 2000 rpm. The vibration is hard enough to shake the windshield pretty hard. It does not vibrate at any other rpm. Does anyone have any idea what could be causing the vibration? Any help would be greatly appreciated.
Old Jun 29, 2011 | 12:49 AM
kkiley's Avatar
kkiley
Have you checked your motor mounts?
Old Jun 29, 2011 | 01:11 AM
Little Mike's Avatar
Little Mike
You said it vibrates as it "goes through" 2000 rpm no matter the gear. What are the rpms at when you shift? If you are shifting below 2k it could be that you are bogging the engine.
Old Jun 29, 2011 | 04:59 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
I'd put an eyeball on the motor mounts, and see if all is well.
If they are, next move would be to measure pinion shaft run out.
Scott
Old Jun 29, 2011 | 06:30 AM
prodrag1320's Avatar
prodrag1320
top motor mount too,lots of riders over look it
Old Jun 29, 2011 | 06:58 PM
Ghosty's Avatar
Ghosty
Well no I have not checked them. The bike has pretty much been a garage queen and only has a little over 12K miles on it. I'll give all of the mounts a good look see . Thanks.
Old Jun 29, 2011 | 07:01 PM
Ghosty's Avatar
Ghosty
I'm not lugging the motor. The vibration occurs in first going up in rpm or coming down in rpm as well as other gears whenever I'm at 2K rpm.
TurboGliding
Sep 13, 2017 06:43 PM
ebross217
Shovelhead
17
May 31, 2017 11:11 AM
lottinala
May 25, 2007 02:24 AM
Tltrump
Dec 12, 2006 12:51 AM
kman42oo
Nov 9, 2005 08:42 PM
